Results 1 to 9 of 9
Thread: Hi everyone
    leeds
    Default Hi everyone
    Have been registered on the forum quite a while but have just bought my Signum.
    Having read a lot of info on here I decided to get a 2.0T elite. Thanks to everyone who posts useful info which helped me make a choice. Am really pleased with it but not the headlights though
    How do I post a question in the technical section as I made a mess of changing one headlight bulb and now the levelling doesn't work properly. I just can't see anywhere to click to start a new question.
    Cheers
    Jan 2009
    WGAF#5
    Hi David,
    nice choice in motor
    i think you will find that youy need to be a full member to access technical info ... £15 well spent imho
    are you sure the bulb is in correctly and located in its lugs - if not then the levelling will not work correctly
    that would be my first point of checking
    regards
    Dez
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    hello and welcome along
    Regular Member parsco's Avatar
    Cambridgeshire
    Regular Member shaun260589's Avatar
    Jun 2009
    Newcastle
    welcome along mate
    leeds
    thanks for the welcome everyone.
    Deztroyer thanks for the suggestion. The bulb is in properly but I didn't mention that I accidentally removed the level motor before I realised it wasn't the bulb!! It can't be back in right as although it adjusts ok, the aim is too high. Also the bulbs seem to be free to rock up and down an inch or so if you grab the bulb holders.
    Wonder what I have done, feeling a bit of a prat
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Vectra
    Engine : 1.9 CDTI 150
    to the site,
    Bri.
    Dec 2007
    Trim : /Elite
    Engine : 2.0 CDTi
    Mileage : 34900
    Welcome to vectra-c.com m8
    and still loving it
    Jan 2009
    WGAF#5
    ahah !
    maybe the motor isnt seated correctly then ..... worse case scenario you broke the mount
    best to remove both headlights so you can clearly see them with one correctly fitted and HOPEFULLY one not!
    not a five minute job - but hopefully will be worth the time and save you some money
