Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Radio turns on every time I start the car
    Regular Member FazerMonkey's Avatar
    Cheshire
    Default Radio turns on every time I start the car
    This is driving me mad. I've searched the threads but can't find one on this........the issue is that every time I start the car the radio turns on, irrespective of whether it was on or off when I last stopped the car and turned the ignition off. I've got Ignition Logic set so that the radio works when the ignition is on I just don't want the radio to start every time I start the car. I.e. I'd like to choose if it goes on, not the car making the decision for me. Is there anyway to turn this 'feature' off and make it behave like every other car I've owned?...or is it a fault?
    Cambridgeshire
    Mine does the same. To be honest it's never really annoyed me because I always like to have the radio on anyway so it's just one less thing I have to fiddle with when I get in the car
    spoons
    Guest
    I thought 'ignition logic' did this for you and is programmed per key..
    I also prefer it this way
    Key in = radio on
    As soon as I remove the key = radio off
    There is a section in the audio manual for manual radio control...
    I'm just reading it, same instructions for all models, dotted throughout the manual
    Disabling automatic switch-on
    Switch on ignition
    Switch off radio
    Press presets 1 and 3 and keep pressed in
    Display will show IGNI ON
    Confirmation bleep
    Display will show IGNI OFF
    Confirmation bleep
    Release
    Try now
    Cheshire
    Quote Originally Posted by spoons View Post
    Ignition Logic allows the radio to either ("on") work when the ignition is switched on/radio switches off when ignition turned off (like almost every other car) or ("off") work independently of the ignition i.e. you can turn it on when the key isn't in etc. Annoyingly with this is setup is that when you take the key out after a drive the radio stays on whatever.
    My issue is slightly different in that I've got it set to "on" i.e. power to the stereo is delievered when ignition is turned on it's just that it doesn't remeber what state the radio was in when I last got out of the car. If I get in and start the car the radio comes back on even if it was off when I loast drove; what is this nonesense?
    Cheshire
    Switch on ignition
    Switch off radio
    Confirmation bleep
    Confirmation bleep
    Release
    Will try at lunch..........but either way, thanks, very much what I hoping for. Couldn't find anything like that in the manual, perhaps it was the blind rage that clouded my vision.....
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Mine does it, too, and goes through phases. Sometimes it always turns on, sometimes never. Sometimes it plays the CD, sometimes not.
    Mine's a prefacelift CCR2006, with ignition logic enabled. When I mentioned it to my dealer, he just raised his eyes to heaven and said that VX keep saying there will be a fix for it, one day.
    Phil
    Regular Member Readster's Avatar
    Plymouth
    Scroll through the programmes on the radio unit using the buttons.
    IGN LOGIC ON - OFF is an option.
    OFF and its manual but, it doesnt turn off when your turn the ignition off...
    ON and its ignition controlled.
    Not the best system I agree, but that what we have here.
    John
    Apr 2008
    Burton on Trent
    I turned this off on my wife's Zafira but something else stopped workinag and can't remember what it was, but I enabled it again.
    Cheshire
    Switch on ignition
    Switch off radio
    Confirmation bleep
    Confirmation bleep
    Release
    Tried it but nothing. Even kept the buttons pressed in for 30 secs, still nothing. Is this definitely the right order? I've not got the manual to hand to re-check.
  1. Vectra turns over but will not start
    By TI7ANIC in forum Engine & Drivetrain
    Last Post: 24th August 2011, 16:32
  2. HELP! Car wont start, Engine turns over.
    By CDTI120SXI in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd July 2011, 13:57
  3. Second time i've had to jump start the car...
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 26th January 2010, 23:23
  4. 1.9 cdti turns over but fails to start
    By swifty776 in forum Engine & Drivetrain
    Last Post: 9th January 2010, 22:57
  5. 1.9 120 cdti turns but won't start
    By weatherforcast in forum Engine & Drivetrain
    Last Post: 3rd March 2009, 14:25
