Results 1 to 10 of 17
Thread: z22se clicking
    Regular Member denzilbud's Avatar
    cambridge
    Default z22se clicking
    hi there hope someone can help,when i turn the ignition off there is a click from engine bay any ideas its a 52 plate 2.2,also there was a video kicking around about the sound of a cam chain rattle any body got the link as i cant make up my mind to weather my car needs cam chain replacing or its a tappet
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    If the clicking happens when you turn the ignition off then its not going to be the chain or hydraulic lifters as the engine's not running. Is it not something electrical?
    cambridge
    sorry mate their two differnt problems
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by denzilbud View Post
    LOL, read it again, got you now.
    cambridge
    the tapping noise seems to be more regular now but only when engines cold and been stood over nite
    Vehicle : SRi
    Mileage : 137000
    My Hydraulic lifter noisy Vid
    Vehicle : SRi
    Mileage : 137000
    I noticed you searching through my threads, mine was worse with a warm engine, not hot not cold but if it had been driven left to sit for an hour then started it again. Thicker 10w 40 oil helped it quite a bit.
    cambridge
    yeh that be the noise looks like an oil and filter change would flushing some cheap oil through it first help any
    Vehicle : SRi
    Mileage : 137000
    Could do mate, just as long as your engine has been flusher on a regular basis before or it could make it worse.
    cambridge
    ok cheers mate any ideas on the clicking sound when ignition switched off
  1. Z22se
    By Paddy in forum Engine & Drivetrain
    Last Post: 1st April 2011, 14:02
  2. z22se mpg
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 19:03
  3. vec c egr(z22se)
    By denzilbud in forum Engine & Drivetrain
    Last Post: 3rd July 2009, 11:36
  4. z22se in a vec c
    By benny in forum Engine & Drivetrain
    Last Post: 30th August 2007, 00:05
