Thread: Upgrade brakes on '07 Vec CDTi Sri 150?
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    Default Upgrade brakes on '07 Vec CDTi Sri 150?
    So what can be fitted to this then with 18" wheels? Any other GM motors that are compatible?
    I'm a big fan of good stoppers, especially if I can get em cheap!
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    314MM upgrade from LMF, mention your a vec c member for good discount. Failing that, try a Saab dealer .
    Sep 2009
    Fife
    Trim : M Sport
    Engine : 3.0 TT
    Cool thanks. Is that a standard fit on a saab 9-3 then? Will the calipers go straight on?
    Full Member Big Sig's Avatar
    Saab 93 areo = 314mm. Vec 3.2/3.0cdti also = 314mm
    VXR 345mm will also fit under 17/18" wheels
    WGAF#5
    told you this site was going to cost you lots of money
    Cambridgeshire
    The 314's are worth EVERY penny on the 150 mate. I don't know why they didn't fit them as standard to be honest
    Regular Member Wilco's Avatar
    Aug 2007
    Quote Originally Posted by parsco View Post
    I'll second that, they are absolutely fantastic.
    Sep 2009
    Fife
    Trim : M Sport
    Engine : 3.0 TT
    Lol you're not wrong!
    So...I've been offered a full set of front brakes off a breaker vxr - discs, pads, calipers and carriers for £350. Fair price?
    I'm assuming they will fit ok and not cause the master cylinder any problems...?
    Why does everyone keep forgetting about the rears!?> doing the front only
    Current :
    Front : 285mm ventilated
    Rear : 278mm solid
    Upgrade :
    Front : 314mm ventilated
    Rear : 292mm ventilated
    You will also need the brake bias checked and adjusted after fitting
    The full service stopping distance will be reduced by about 6%
    Cambridgeshire
    Only because most (not all) of the braking is done with the front brakes. I just wanted to bring mine into line with the 3.0 V6 diesel with 314 front and 278 rear as they work fine. I also upgraded the brake hoses to braided ones (Goodridge) all round and that also helped make the pedal much firmer
  1. looking to upgrade my standard brakes?
    By VECTRA1974* in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2011, 13:13
  2. Upgrade Brakes?
    By parapaul in forum Handling & Braking
    Last Post: 3rd September 2010, 02:54
  3. upgrade rear brakes?
    By aerodynamic18 in forum Handling & Braking
    Last Post: 23rd May 2008, 20:45
  4. What brakes upgrade do you guys recommend?
    By Daves Blue SRi Vectra in forum Handling & Braking
    Last Post: 10th December 2006, 23:26
