Results 1 to 10 of 21
Thread: winter wheel protection and another damage limitation exercise
    Regular Member Lump's Avatar
    coventry
    Default winter wheel protection and another damage limitation exercise
    so had to take off the wheels today as i have MOT next week and wanted to have a check under the car. so whilst they were off sorted out another few hits on the wheels and gave them a few coats of FK1000p took most of the day. as it was nice weather and id been putting it off for weeks thought best get it done
    Full Member gibbon7000's Avatar
    lincs
    whats fk1000p lump??
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    coventry
    hope this helps
    Finish Kare #1000P Hi Temp Sealant
    Price: £17.95
    Product code:
    FK1000P
    Brand:
    Finish Kare
    Finish Kare 1000P Hi-Temp Sealant is developed from a West German process called Synthesis, 1000P is a blend of advanced pure synthetic materials. The result is a paste wax characterized by melting temps of 250+ degrees, extreme hardness, extreme slickness, high gloss, and intensive wear without the quality fluctuations found in natural waxes.
    1000P delivers heavy duty resistance to UV, hard water, acid rain, bug spatter, tree sap etc while creating a customer appearance.
    Excellent for use on all automotive paint, gel coat and metal surfaces including critical aircraft surfaces.
    Specifically Designed For All Marine Aircraft And Automotive Finishes.
    Cleaning: Low0 12 3 4 5 6 7 8 910High
    Gloss: Low 0 1 2 3 4 5 6 7 8 910High
    Depth : Low 0 1 2 345 6 7 8 910High
    Protection: Low 0 1 2 3 4 5 6 7 8 910High
    Durability: Low 0 1 2 3 4 5 6 7 8 910High
    Size: A HUGE 15oz tin.
    SP Notes: One of the best looking sealants used to date.... Great looks, easy to use and awesome protection! 'Bang for buck' you won't get a better finishing product anywhere!
    Mileage : 000
    Quote Originally Posted by gibbon7000 View Post
    Lump put me on to this stuff. I can not recomend it highly enough. It has to be up there with Colinite 915.
    Well worth trying. You will be amaized with it.
    blackpool
    is it any good? its not cheap but new alloys aren't.
    coventry
    Quote Originally Posted by jcarcass View Post
    not cheap £20 to cover your body work wheels for a few years ?
    Mileage : 000
    It is cheap in comparison to other products you can buy. But this stuff is good. I can tell you.
    lincs
    Thanks for that, I might have to invest in a pot
    Regular Member johnnyg's Avatar
    May 2007
    manchester
    ed how would you rate it against collinte 915 just run out so looking for to replace with the same or an alternative
    cheers jon
    coventry
    drop me your address ill pop you out a sample
  1. Winter protection
    By Corey in forum Detailing and Car Care Discussion
    Last Post: 30th October 2012, 18:33
  2. winter wheel colour
    By neverlandandy in forum Styling
    Last Post: 26th September 2010, 15:55
  3. Damage to alloy wheel
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2009, 16:19
  4. wheel damage
    By ALD in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2006, 15:37
