Thread: Vectra Rear Brakes!
    Sep 2009
    midlands
    Default Vectra Rear Brakes!
    Hi
    Vectra
    2007
    32k
    Within the last few days i've had a problem with what seemed to be the passenger side rear brakes. So took it to Kwik fit this morning to get a free brake check. They found the passenger rear side inner brake pad had completly worn away but the outer pad was perfect.
    They said the pad, disc and calliper would all need to be replaced. This would all cost around £400! The cars still under warranty, but I can't see them fixing this under warranty? The problem has come along within days and needs to be sorted quick.
    I'm wondering how I should approach this
    Any advice is appreciated!
    Mileage : 000
    I am not sure if it is covered under the warrenty. But it does sound like the piston/caliper is faulty. Best to go along to you local VX dealer and have a word with them, after all you have nothing to loose.
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    if the calipers faulty they should change it under warranty
    Regular Member mcints77's Avatar
    Jul 2009
    Tomintoul- Scotland
    Vehicle : SRI 1.9 CDTI 120
    Trim : SRI
    Mileage : 62000
    second opinion always good with kwick fit bunch of cheating ********!
  1. Rear brakes sticking (vectra)
    By Steve 100 in forum Handling & Braking
    Last Post: 6th July 2012, 08:05
  2. New rear brakes fitted on the Vectra B
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2010, 21:29
  3. vectra vxr front and rear brakes
    By tbs in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2009, 22:43
  4. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
