Thread: Vectra 2.0 Diesel engine warning light
    Sep 2009
    Default Vectra 2.0 Diesel engine warning light
    Hi,
    Ive got a vectra 2.0 diesel just done 85k on the clock,
    Ive recently been losing revs where its limited to 2750 and very sluggish getting there and getting the spanner warning light on the dash,
    Anybody know what it could be or could it be a multitude of issues,
    Cheers G
    11 Post(s)
    Car/spanner light - engine electronics, autobox (if fitted) and immobiliser fault light.
    Your car has gone into limp home mode. You need to get the fault code(s) read out.
    Sep 2009
    The cars a manual,
    How do I get the fault codes? Is it something I could do or do I need to take it to a garage, pull my pants down and pray they lube up
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Could be the boost hoses or vacumm pipes split or possibly the boost sensor but really you need to have the fault codes read.
    Regular Member bigbnlr's Avatar
    Belfast
    check the vac hoses the 2.0 dti are known for splits. try this first before you spend any money its normally the ends that split. good luck
    Sep 2009
    Oh well,
    Been today to get the codes read, 1st was my mechanic who only has a hand held, nowt shown so he said to try it at somewhere with a better piece of kit so I did,
    No faults,
    Is that a good thing or a bad thing I am now asking myself
    The codes are usually only stored for up to 10 ignition key entries, so looks like you left it too long
    Next time it happens, take your car straight to a VX dealership and prepare to part with up to £60 just for the codes to be read
    However you can usually haggle and have them deduct this as part of the overall repair cost (How can you repair the car without the diagnosis)
    Sheffield
    I had the same thing and it turned out to be my EGR valve, I cleaned it and it still went into limp mode and spanner light, I ended up replacing it with a new one at a cost of £214 and 10 minutes to fit myself. No problems since.
    Good luck
    Sep 2009
    Not a clue then, parked the car up Sat and took it to the garage today so if what your sayings right the codes should have still been there.
  1. Warning light - little pic of an engine
    By ian1963 in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2010, 17:20
  2. Engine warning light
    By shamus5178 in forum Engine & Drivetrain
    Last Post: 15th July 2009, 21:08
  3. Exhaust Gas warning light on a diesel?
    By jlheath in forum Engine & Drivetrain
    Last Post: 30th September 2008, 11:08
  4. Engine Warning Light
    By harveyg77 in forum Engine & Drivetrain
    Last Post: 5th June 2008, 20:35
vauxhall astra 2.0dti diesel warning lights
vectra c engine warning light
