Thread: Strange brake problem
    Nottinghamshire
    Default Strange brake problem
    I thought my brakes felt a bit "long travel" so i pumped them a few times and then the brakes felt ok again - i thought the brakes were supposed to be self adjusting for pad wear etc? after a few days the brakes go back to there long travel self. It also seems that the brake lights stick on when the brakes feel right (not long travel) and then it seems to retard the cars performance electronically. If i push the CLUTCH pedal to the floor, the brake lights come on, any ideas?
    Jul 2009
    sussex
    have you checked the fluid resevoir?
    when you say the brake lights, do you mean the warning symbol on the dash or the actual brake lights on the tail gate?
    the only association i can see between the clutch and the brakes is that the clutch is hydraulicly actuated and as such uses the same fluid that the braking system does.
    Nottinghamshire
    When i say brake lights i mean the lights on the rear of the car. The fluid level seems OK
    Jul 2009
    sussex
    does the engine idle dip when you force the pedal down hard?
    Nottinghamshire
    Not noticed it.
    Check the brake servo, try this
    Observe where the brake fluid level is on the reservoir
    With the engine off, depress the brake pedal ONCE and keep the pressure on
    Switch the engine on
    As you switch the engine on the brake pedal should depress further
    Compare the brake fluid level, it should be unchanged
    Have the brake pads been replaced recently?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    sounds like you have brake master cylinder seal passing fluid,pumping pedal brings fluid level up in master ,as you use brakes fluid passes past seal giving longer travel
  2. strange problem
    By marktaylor in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2012, 16:05
  3. Strange problem
    By Graeme in forum Bodywork & Interior
    Last Post: 19th March 2011, 15:22
  4. strange brake light fault
    By Bethan39 in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2010, 14:55
  5. strange problem, help please
    By adamjukes01 in forum Engine & Drivetrain
    Last Post: 26th January 2008, 21:55
