Results 1 to 3 of 3
Thread: Soot and funny smell
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Default Soot and funny smell
    Hi guys I really need your help
    After unblocking the bung and curing the wet carpet- i started to notice a strange smell, my thoughts were pollen filter contaminated-so went to order one, upon looking under the bonnet i've found there is a lot of soot all over the engine , and the pipes around the area where the egr is are coated with it , any help would be appreciated as rather than breathing in wet filter- it must be carbon monoxide!!
    cheers
    Andy
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    Maybe the egr pipe is split? I'm sure I read of someone on here with a similar problem. Would be worth having a check.
    North Yorks
    have you noticed any juddering or poor performance? have you had the EGR valve replaced at all?
    WHen does the smell come to notice? and is it in the cab or do you mean when stood next to the car?
    I have a smell in the cab when stationary, its not pretty, think it is because the bar that runs across the outlet manifold (i forget the name of it) is off at one end ( i have since discovered today it is off completely and will all need fixing ) and the smell leaks from there, as a result of it having come off completely, there is soot all over the top of my engine and a shiny liquid looking subtance around the place.
    Any way, could be that or the egr itself.
  1. Funny Smell
    By matt2005 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th December 2011, 00:00
  2. dpf and soot???
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 9th July 2010, 14:33
  3. Funny Smell from Airvents
    By sirk696 in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2009, 17:11
  4. Funny smell after Air Con is turned off
    By squigles in forum Bodywork & Interior
    Last Post: 9th June 2009, 07:15
  5. 1.9 cdti (120) funny smell on first starts ?
    By Vectra-c-SRI in forum Engine & Drivetrain
    Last Post: 4th November 2008, 00:01
