Results 1 to 2 of 2
Thread: ABS ecu prob
    Regular Member CBag7's Avatar
    Apr 2009
    South Glos
    Default ABS ecu prob
    Hi I started a thread about this before but things have progressed.
    My problem is this...
    I can be driving along quite normally and the needles start jumping and then all of a sudden I will lose my speedo, rev counter and all the other dials. The ABS light is on and so is the battery light.
    The car is still completely drivable with no other problems.
    If I stop and then restart the vehicle then everything is restored.
    This wasn't a problem to start with as it would only do it every now and then but its becoming more of a problem and I have to have my sat nav permanently on to use its speed read out to ensure I'm drving within the limts.
    Took it to vauxhall this morning and they have blamed it on a misfitting asb loom plug and want to charge me £221 to fit a new plug.
    I have just done a few searches on the net and have found a few people who have had this work done and it hasn't fixed the issue.
    Has anyone else had the same prob.
    Im gonna clean the contacts later and maybe put some contact fluid on them to see if it solves the prob (no water present either).
    Gary
    Regular Member benny's Avatar
    Feb 2006
    dudley
    it isnt the contacts are dirty or water has got in the contacts on earlyer cars were different size's in each plug so one terminal will push the other one out and will give a bad conection eventually ...... the plugs used to be around £16 i think from mem ...loads a wires to be joined and swopped ..........
  1. egr prob
    By landynigel in forum Engine & Drivetrain
    Last Post: 14th March 2012, 15:21
  2. Air con prob
    By graycbox in forum Introduce yourself.
    Last Post: 19th July 2010, 22:15
  3. i think i have a prob
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2009, 23:09
  4. 2.2 sri prob
    By junior72 in forum Suspension, Wheels & Brakes
    Last Post: 15th August 2008, 22:37
  5. MPG Prob?
    By Basil in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2005, 19:46
