Results 1 to 10 of 21
Thread: quick 3ltr v6 diesel question...
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default quick 3ltr v6 diesel question...
    right one for the tractor lotion boffins my mate has a 3ltr v6 o5 reg in at his work and it wont start, it has been bumped up the back end lighty and has been repaired at the garage but it wont start at all,i was wondering if these motors have a fuel cut off switch? if so where would it be found???? its just turning over and over,
    its been on the computer and its saying no fuel getting to the rail,the pump is working as you can hear it.
    Sounds like some sort of fuel cutoff, no idea where you'd find it though and don't have access to my Haynes...
    Cumbernauld, Scotland
    Fuel cutoff switch
    Open the bonnet
    Back of the engine
    Plunger looking item, with a button on top
    Press firmly
    However, since this is a diesel, if you have been running the engine before resetting the fuel cut off switch then you may need to reprime the fuel system
    Regular Member m3ath3ad's Avatar
    Aug 2007
    Minehead
    Quote Originally Posted by m8internet View Post
    Fuel cutoff switch
    Open the bonnet
    Back of the engine
    Press firmly
    cor where would be without you on here?
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Don't suppose a 2.2DTi would have this would it? Mine tonight as decided it doesn't want to start, seems to be an incurable problem which is getting on my goat now, it is on a VERY mild incline facing up
    Quote Originally Posted by si_hoss View Post
    If you get it to a filling station, fill it to the max and then don't let it drop below a half or 3/4... Had this on my old 2.2 DTi Vec B and put it down to a dodgy tank sucker-upper pipe type thing. Always filled it at 2/3's and never had a problem after that...
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by Penfold101 View Post
    Hmmmph!!!! Thanks for the advice, I get this issue normally around 1/4 left, but in this day and age I should be able to park a car up hill, on reserve and leave it there for more than 24hrs!!!! ARRRRGGGGGGGGGGGGH!!!!!
    My borther's gonna tow me round the block a few hundred yards tomorrow morning, I'll fill it up then too. Cheers!
    I think that maybe something had come loose in the tank - without knowing the makeup of it it's hard to say, but it cured it...
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    Does it have 2 pumps like the high pressure system on the directs? One in the tank and one on the rail?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    no fuel cut off fitted on a vx car .... also no fuel pump in the tank on a 3.0 i would start with the tank tho has it moved have any pipes come off ...just a note have the bshop removed any doors to paint any thing ? ,..
  1. 3ltr derv boost
    By Petiemc in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2013, 12:48
  2. Vectra c 3ltr v6 fault code
    By crayon in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2011, 11:58
  3. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  4. quick question about diesel filter
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2009, 00:00
signum 3.0 fuel cut off switch
