Thread: Installed Caterman chip 150 SRI CDTI, but revs going high on idle? Why?
    Aug 2009
    Bradford
    Default Installed Caterman chip 150 SRI CDTI, but revs going high on idle? Why?
    Hey guys
    Bought a Chip from here and the revs are going high and i can't even accelerate when the chip is connected, why is that? Do I have to reset something?
    Help appreciated
    [Ex]Admin Duncan's Avatar
    Have you connected the plug the wrong way round. It's easy to do from what I can recall. i.e. it's 180 degrees the wrong way.
    Aug 2009
    Bradford
    Seemed ok to me. Don't think you can connect it wrong way even 180 degrees, not sure :S
    Feb 2007
    North west
    try it the other way, thats exactly what happens if its wrong way round
    Regular Member vanquis1979's Avatar
    gainsborough
    yep change it round on the engine side i did the same
    Aug 2009
    Bradford
    Yep, rotated 180 degrees and it is working perfectly fine
    Aug 2009
    Bradford
    thank you guys for help
  1. High idle revs
    By Kaz in forum Engine & Drivetrain
    Last Post: 15th December 2013, 23:18
  2. idle/low revs
    By srikev in forum Engine & Drivetrain
    Last Post: 2nd October 2012, 19:21
  3. Replies: 22
    Last Post: 5th September 2012, 13:25
  4. high revs when hot
    By mentor in forum Engine & Drivetrain
    Last Post: 26th May 2011, 12:36
  5. Help - High idle (1000 rpm) and high map reading
    By roswell in forum Engine & Drivetrain
    Last Post: 5th April 2011, 21:49
