Thread: Coolant leak on 53 plate 1.8LS
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    Default Coolant leak on 53 plate 1.8LS
    Ive got a coolant leak on my vec.
    It looks like its comin from the radiator somewhere above the drainage tap. I can see a couple of runs down the side of radiator, and a small puddle under that area on the floor.
    I just wanted to ask if anyone knows of any common things to look at round that area.
    Any help would be great.
    Carl
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Carl have a pressure test done on cooling system all will be revealed
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    If it's any consolation. I've got a leak in the same area. Sometimes leaves a little pool on the drive, sometimes it doesn't.
    Getting it sorted soon when I have my timing belt done.
    Thanks fo the advice, i think ill have a pressure test done, will be alot quicker findin the leak!!
    John C S - mine sometimes leaves a puddle and sometimes doesnt. Let me know if u find out what it is, ill let u know if i find it.
    Jul 2009
    lanark
    gaurenteed to be the radiator, vauxhall rads are not as good as they used to be, i work in a dealer and change them every day more or less
    Jan 2010
    croston lancashire
    its at the bottom where the drain plug is mine is there and its where the seal is going to jb weld it in the morning see how it goes. then will get a new one from europarts 91 pounds they are
  1. 2.2 coolant leak
    By jrh1 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th September 2012, 18:07
  2. Coolant leak
    By Vin in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 22:49
  3. Coolant leak!!!!!!!!!!!!!!!!!!!
    By gregc in forum Engine & Drivetrain
    Last Post: 14th August 2009, 09:17
  4. Coolant Leak???
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2009, 05:46
  5. 2.0T Coolant leak
    By mark1319 in forum Engine & Drivetrain
    Last Post: 19th December 2008, 22:53
