Ahhh, I thought you were going to say it was an aftermarket radio
It obviously should be showing the radio station / CD info already so I suspect it is either faulty, or has been swapped, or, someone has been using a programmer on it and messed up the settings.
I'm sure that one of the Tech2 guys can probably offer some advice here
@ThatAudioBloke @Robsey @plasma ?
HTH
It'll probably have EHU set to "not installed" in the low speed can config. Plod cars are usually specced without the radio, so it may have been retrofitted with the cd30.
Should just need a bit of plugging in and tweakery tbh.
No, I think that's setting "anti theft without EHU" on the DIS from memory, but I may be wrong.
You can set the canbus config as much as you like.
Nah, it'll need plugging in to tech2 see what's what.
