Thread: washer nozzles
    manchester
    Default washer nozzles
    my washer jets only trickle on drivers side and on the back,motor is running so not that. any ideas cheers rick
    manchester
    ps.tried the sewing neddle did not make a difference
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    the washer bottle will need a clean out, the filter gets clogged up..
    Regular Member signum junkie's Avatar
    Edinburgh
    If you have a tyre compessor, then remove tube from nozzle and put end of compressor with the pointy adaptor I think used for footballs and the like into the end and switch on this should get rid of blockage. Did this to mine when they wouldn't work and have no probs now
    manchester
    thanks mate try that in the morning
    Edinburgh
    No probs m8 just remember to remove filler cap on washer bottle or it may be a case of There She Blows!
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by Gr4eme View Post
    Nottinghamshire
    I had this symptom with my car and the solution was really wierd.
    I did the obvious stuff first - checked the pump was OK and that the filter it sits in was clear, and that the nozzles weren't blocked (I replaced the driver side one to be sure). These were all OK but there was still loads of water coming out of the passenger side nozzles but hardly any on the driver side.
    I started disassembling the pipework at the various joins and found that the pipe between the passenger side nozzles and the driver side nozzles had swollen up inside and blocked itself up! In case you haven't looked yet, the pipe runs from the pump in front of the nearside front wheel into the passenger side nozzle and then another pipe connects the passenger side nozzle to the driver side nozzle.
    The pipe is available by the metre from a dealer and the washers on both sides worked fine once the new pipe was in place.
    Regular Member old cruiser's Avatar
    slough
    This is normally the main culprit, you'll be surprised what slimey crap has clogged up that little filter!!
    Cheers Pete
    manchester
    thanks everone it was a blocked pipe on drivers side,took it to equip in eccles,manchester (cos i got fed up trying myself) who does my work on car(its a taxi) had 2 new tyres done my nozzles back and front and got a 10 pence coin out of my seat runner (which took 30 mins) and only charged me for 2 tyres 140 quid,bargain or wot
  1. Replies: 6
    Last Post: 29th December 2012, 17:32
  2. Injector Nozzles
    By john506 in forum Engine & Drivetrain
    Last Post: 4th July 2012, 18:30
  3. Heated windscreen washers Nozzles faulty
    By lee_eardley in forum General Chat
    Last Post: 17th December 2007, 19:29
  4. Heated washer nozzles
    By Ste in forum Bodywork & Interior
    Last Post: 3rd April 2007, 14:18
  5. Heated windscreen washer nozzles?
    By stevedee3 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2006, 03:00
