Thread: Wiring audi style lights
    Apr 2009
    Suffolk
    Default Wiring audi style lights
    Can anybody help me with wiring audi style led lights. Ive just got a pair and want to mount them under the fog lights (i know, not everyones cup of tea). Could somebody advise me as to how to wire these in, thanks.
    Regular Member signum junkie's Avatar
    Edinburgh
    What are you ging to wire them up to m8? Side lights or seperate switch? If its to seperate switch I can help but no idea to side lights
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Pull the wires from the side lights out, slice off a bit of the platic cover to reveal wire so can connect your new wires to it (form a t-shape)... attatch new wires and cover with tape or heat shrink. job done...
    Just get the + and - right way round...
    Edinburgh
    1. You will have to remove glove box by taking of moulding on dash by just prising it off gently from passenger door end
    2. remove torex screws from glove box and remove glove box light
    3. locate large rubber gromit where wires come through from engine and feed wires through(I used slim flat bladed srew driver to lever this open this enough to feed wires)
    4. If you want to feed wires behind console I found removing lower cubby above ashtray will give you access
    5. If you want to fit seperate switch the cubby hole is perfect for this and you just need to drill a hole in the back of this and attach switch. There is also a metal strip below it so you can attach an earth wire
    Hope this helps
  1. Audi style lights.
    By Ben999 in forum Styling
    Last Post: 16th May 2010, 10:33
  2. Audi style led lights probs
    By the_wave_rider in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2010, 12:21
  3. audi style DRLs
    By ilkerkula in forum Styling
    Last Post: 31st October 2008, 07:57
