Thread: glow plug relay and glow plugs
    Sep 2009
    rochdale
    Default glow plug relay and glow plugs
    Have just had vectra 1.9 cdti to garage to get spanner warning light diagnosis the result was that the glow plug relay is sticking and needs reopacing together with all 4 glow plugs. Am reluctent to spend the £300 quoted
    does anybody know it this is a job that can be done at home and if so where is the relay and how do i go about it and the glow plugs
    any advice welcomed
    Ta
    East Midlands
    You can DIY for about £80 odd if you're anywhere decent with spanners.Don't know where relay is ,i'll see if i can find it in Haynes.give me a minute.
    Sep 2009
    rochdale
    thanks for that
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    Looks like they're not sure on what wrong so are just changing everything! Glow plugs are approx £20 a pop so £80 IF the plugs are faulty, normally its only one or two and the relay approx £30 i'd say.
    changing the glow plugs is normally a matter of unplugged the lead from the end and then using a 10mm deep reach socket to remove them (think its a 10mm, and also squirt some wd40 on the plugs to loosen them, when the engine is cold though)
    as for changing the glow plug relay as whats his name above said, need to check on that..
    edit: Glow plug relay/control unit.. Its near/on the battery, think it hangs off of it. Its metal about 3-4inchs rectangle and has 'alloy fins' on it
    East Midlands
    Glow plug relay....Look under the bonnet and it's positioned near the battery on the right hand side of the engine bay as u look at it,silver box,about £30 from dealer,set of glows you can get for£30 or £40 from the bay hth.
  1. glow plug relay
    By iwtand in forum Y & Z30DT Specific
    Last Post: 29th January 2012, 14:25
  2. glow plugs relay switch
    By robengland9 in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2011, 19:11
  3. V6 Cdti glow plug relay
    By Critch in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2011, 16:31
vectra c 1.9 cdti glow plug relay
where are heater plugs in 08 vectra diesel
vectra c glow plug relay 1.9cdti location
vectra 1.9 cdti glow plug relay
2007 vauxhall vectra glow plug relay location
vectra c 1.9 cdti glow plug relay getting hot
1.9 cdti glow plug relay location
corsa c changing glow plug relay
location of relay for glow plug vectra 1.9 cdti
opel vectra 2000 glow plug relay
where is the glow plug relay on a vauxhall Vectra
location of glowplug relay vectra cdti
vectra c glow plug 4 not glowing
Vauxhall vectra c 20 diesel glow control relay
vectra c glow plug relay module
vectra c 1.9 cdti glow plug fuse
vauxhall vectra sri cdti 150 glow plug relay location
vectra c pre heating relay location
2005 vauxhall astra 1.9cdti glow plug relay
vauxhall vectra 1.9 diesel glowplug relay
image glow plug relay astra diesel
how to remove glowplugs leads vectra 1.9cdti
where is the glow plug relay vectra c 1.9cdti 2005
vectra cdti glow plug relay
