Thread: clicking noise when i unlock car
    Regular Member KevinG's Avatar
    South Bucks
    Default clicking noise when i unlock car
    Hi
    This all started when i had my aircon regases, first when i turned the aircon on i would get a clicking noise coming from what seemed to be under the passenger dash, also got a slightly deeper clicking noise when i clicked the recycle air button.
    Now it happens when i unlock the car, then if i leave it unlocked when i open any of the doors, it lasts about 10 seconds.
    Any ideas?
    South Bucks
    think i may have found the answer. Air temp mix servo motor
    Mileage : 000
    Or even the air recirc" servo. Try switching that on and off. If it makes the clicking noise when you turn it off then that is what is broken. They have a habit of breaking a tooth off. Do a search for recirs servo, you should find some info" about it.
    South Bucks
    Quote Originally Posted by ed taylor View Post
    thanks ed, will do, there is two slightly different sounds, one when i turn on and off the recycle air and another wnen i open the car and turn the ac on and off, knowing my current luck its probably both
    Mileage : 000
    If it is the air recirc servo, it can be got to by removing the glove box. But the rear screw is a bit of an awkward one to remove. If you need any more information on it give me a shout. There is plenty on info" if you use the search function.
    Good luck with sorting it out.
    South Bucks
    thanks ed
    Mileage : 000
    Kevin. What about trying this. Remove the glove box then disconect the recirc sevo, and see if the noise is still there, it might iliminate or conferm the recon servo.
    Have a look here.
    South Bucks
    Have a look here.
    nice one, will hopefully get a chance in the week.
  1. Clicking noise.?
    By telstar in forum Bodywork & Interior
    Last Post: 2nd August 2011, 09:00
  2. Clicking Noise
    By Lynchy in forum Vectra C / Signum Troubleshooting
    Last Post: 25th June 2011, 02:33
  3. clicking sound on unlock
    By big_dave in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2009, 17:28
  4. Clicking noise
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2008, 19:29
  5. Creaking/clicking noise
    By Gogs67 in forum Bodywork & Interior
    Last Post: 12th April 2006, 12:17
