Results 1 to 10 of 14
Thread: 2.0 t noisy belt tensioner
    Cwmbran/Newport
    Default 2.0 t noisy belt tensioner
    Hey all,
    Anyone have a rough idea on how much a it is to replace the tensioner and belt, need to get mine done as the dreaded rattle/vibration has started.
    Just to help matters think that i need the alternator pulley done too.
    Matt
    Tyneside
    Not sure if this is what your referring to as you mention vibration, but it's the common problem known with the 2.0T
    The belt is about £11 and the uprated pulley to stop the squeeking is £120 the last time I checked, but from what I remember Duncan got this and the noise came back. If it's just the squeeking a new belt will stop it for a reasonable amount of time, I've just replaced mine as the squeek came back and at £11 you can get 10 belts which will cover 5 years at a very minimum compared to the pulley.
    I can't recall at what point I got the squeaking back - it was after either the pulley or tensioner had been replaced and I think they hadn't replaced the belt on one of them. Anyway after a belt was put on it was sorted - been squeak free for ages now.
    Regular Member lee's Avatar
    northwest
    Tyneside
    Yep, that's the tensioner - and the usual culprit for the judder/rattle you mention. For the cost of it, make sure they/you stick on a new belt or they'll just reuse the old one sometimes!
    Cwmbran/Newport
    cheers for the info all, complete nuisance this. Pity vauxhall didn't do a recall!
    might try and spread the cost, do the tensioner then the pulley at a later date if the new belt doesn't do the trick.
    Cwmbran/Newport
    so the one above is the correct one to buy, if so then sold
    Yes, if the part number given in the ad is correct then that's the one you want.
    Cwmbran/Newport
    done, just need to get it fitted now or fit it
  1. fan belt tensioner
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 15th December 2012, 11:50
  2. Aux Belt Tensioner
    By tatters40 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 23:02
  3. Fan Belt Tensioner
    By betty02 in forum Engine & Drivetrain
    Last Post: 9th April 2011, 13:15
  4. Cam Belt Tensioner
    By frenchman in forum Engine & Drivetrain
    Last Post: 19th November 2009, 18:46
vectra 2.0t aux belt tensioner www.vectra-c.com
