Thread: mass air flow sensor
    Sep 2009
    birmingham
    Default mass air flow sensor
    hi everyone, 1st post here goes, ive changed the mass air flow sensor on my vectra sxi, but now the revs won't settle when the car is just ticking over, the revs fall to 500rpm then shoot up to 2000rpm, then after a few times of doing this the revs settle on 650rpm, plus as i approach a junction the revs go that low the car stalls. any ideas whats wrong and what do i have to do to get it running smoothly again, any help would be greatly appreciated, thanks
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Not sure why you changed it but if it happened after you fitted the new one then re-do the sensor again and check connections.
    If you search the site you may get the answer that way. Good luck
    Admin - wrong section please change.
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Moved from WM Region page to Troubleshooting - Engine & drivetrain.
    Regular Member Fireyfella's Avatar
    Jun 2007
    York
    Vehicle : Vectra SRi NAV XP2
    Engine : 1.9 CDTi
    Mileage : Plenty
    Quote Originally Posted by vectra craig View Post
    I am not a techy but, it could be your idle control valve, I had a similar issue when I had a Vectra B, replaced this part myself and it ran spot on.
    However, it may be worth waiting for some other suggestions
    Sep 2009
    birmingham
    thnx john, i changed the maf, because the engine management light came on, i took it to a mechanic i know, who put it on a computer and he told me maf was knackered, so i put a new one on (engine management light has gone off) just this revs issue now, starting to do my head in, keeps cutting out as i approach a junction, the revs won't sit on idle there up and down
  1. For Sale: Vectra Mass Air Flow Sensor
    By CraigoT in forum Parts for sale
    Last Post: 25th September 2012, 22:59
  2. Mass Air Flow Meter
    By shug176 in forum Vectra C / Signum Troubleshooting
    Last Post: 31st March 2012, 18:51
  3. Mass Air Flow Sensor
    By stroake in forum Engine & Drivetrain
    Last Post: 13th May 2009, 15:40
  4. Mass Air flow Sensor fault
    By stroake in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2009, 12:34
  5. maf sensor mass air flow for sale
    By mattolly86 in forum Parts for sale
    Last Post: 19th March 2009, 19:42
