Results 1 to 10 of 14
Thread: vectra pedal unit
    Regular Member denzilbud's Avatar
    cambridge
    Default vectra pedal unit
    as title looking at replacing my pedal unit as the clutch pedal return spring went the other day,ive used the modified part but dont like the softness of the clutch pedal,could anyone tell me the work involved,as i can source another unit
    cambridge
    also can someone tell me how to get the cover off from the bottom of the drivers dash(above the pedals)
    cambridge
    anyone
    Regular Member benny's Avatar
    Feb 2006
    dudley
    go to a vx dealer they can suply you with a different type spring set up and you wont need to remove the pedal box its a 10 min fit .... cover comes of with the three screws along the bottom edge the two screws under the colum cowl pointing at you and one under the head lamp switch in the top ...
    cambridge
    manythanks benny this other spring is there differnt one to the modified spring which i bought and fitted
    Regular Member old cruiser's Avatar
    slough
    I think Benny is probably referring to the one you have changed, to be honest mate if your pedal is now returning to the top as it were after fitting the spring and your CC is working ok, I would leave well alone as this could lead to more trouble than it's worth.
    To remove the pedal cover:
    1. remove light switch, by switching to position '0' then push the knob in and whilst holding it in, turn it to the central position, this locks the switch and allows it to be pulled out and the wiring harness can then be removed if needs be.
    2. A screw (torx) should now be seen in the light switch recess, remove this.
    3. The lower panel (covers the pedal area so to speak) has a sort of tray on as it were and there are 2 torx screws recessed in there remove these
    4. another 3 torx screws under the lower edge of the panel
    5.. Pull the panel away and move to one side
    Cheers Pete
    cambridge
    thanks mate is it possible to see the original broken spring once i remove the panels
    slough
    Quote Originally Posted by denzilbud View Post
    FYI, just edited my last post as missed a point out!!
    As far as seeing the broken one , on mine I couldn't see it at all if I remember correctly but I believe it's supposed to be located to the right of the pedal/shaft, sort of coils around the shaft if you see what I mean. does your pedal still not return to the top then?
    Cheers Pete
    cambridge
    it does raise the clutch pedal to where it should be and cc works again but the clutch feels really soft when you use it where as before it was nice and firm
    cambridge
    is the spring the one in the picture
  1. Clutch Pedal Vectra 2.0T
    By neilbroad in forum Engine & Drivetrain
    Last Post: 24th February 2011, 21:56
  2. Insignia/Vectra C/Signum pedal
    By kenp in forum Parts for sale
    Last Post: 13th October 2010, 19:22
  3. vectra c 2003 1.8 accelerate pedal delay
    By sparks in forum Engine & Drivetrain
    Last Post: 11th February 2010, 21:07
  4. 02 Vectra C 2.2 Dti- Brake Pedal Problem
    By Devildriver in forum Suspension, Wheels & Brakes
    Last Post: 3rd April 2009, 15:29
vectra pedals
