Thread: Brake disks size chart?
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Lightbulb Brake disks size chart?
    Just been poking around then forums and realised its a little confusing finding out what size brakes are fitted to the car. Is it possible anyone could put a chart up here of the sizes vs the engine size/model?
    I have a 2.8 V6 Turbo Sig on a 06 plate and am still stuck on what size to buy my rears have got big ruts in them and after the stinky front pads on the passo della stelvio, was going to upgrade all to drilled and grooved with some front green pads So what size? Danke Schon
    [Ex]Admin Duncan's Avatar
    All engines bar the 2.0T and V6 models have 285mm front and 278mm rear.
    2.0T has 302mm front and 292mm rear.
    V6 have 314mm front and 292mm rear expect for very early 3.2s (GSi) that had 302mm front. Seems to be the case also on the 3.0CDTi but I've not yet heard of anyone with a 3.0CDTi that has 302mm as standard.
    VXR has 345mm front and 292mm rear - as does my 2.0T Signum now.
    Bordon, Hampshire
    So I have the bigger size also? As with the diesel V6? How come the Vxr gets bigger fronts and i don't lol? Is it a set of different calipers or could the other bigger calipers fit larger disks??
    Yes, you will have the 314mm fronts. It is possible to get the 314mm calipers to take the 345mm pads - and you'll need the 345mm caliper carriers - but they pads need a bit of careful grinding down etc. It's been done, there's a thread somewhere on it (GSi3.2 did it), but TBH the easiest way is to get hold of the whole kit if you can get it at a decent price.
    Bordon, Hampshire
    danke schon
    Willkommen.
    Oct 2006
    Waterloo, Liverpool
    10 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    The 2.0T and V6 engines also have VENTILATED rear discs as standard
  1. Engine / Brake Disc Comparison Chart
    By Jezzy in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2015, 15:57
  2. brake disks
    By trickyjacks.4 in forum Handling & Braking
    Last Post: 15th February 2012, 15:44
  3. What size brake disks for 2.0dti signum
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2008, 17:11
  4. What size front disks?
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2007, 23:06
  5. corsa brake disks
    By jonno_07 in forum Handling & Braking
    Last Post: 16th September 2006, 08:21
brake disc size chart
