Results 1 to 2 of 2
Thread: 1.8 engine problems running/power
    Regular Member billyyoung's Avatar
    dundee
    Default 1.8 engine problems running/power
    hi all
    i have a 52 plate 1.8. a few weeks ago my car started to stutter when pulling away and in second gear but once moving it seamed ok. a few days after the management light came on. i bought a code reading software and got a couple of codes and reset the light i also changed the front lamda.this was ok for a day the management light was out and the stuttering was away. the light then came back on with the same fault as above stuttering when pulling away , then it started to run rough on idle once it sat for a while . first thing in the morning it would run rough and also pop or backfire through the air intake the same code came up p0170 but it now has started to run funny driving . if you sit at a stead 30 mph it feels like the engine is kicking you feel a little surge on and off as you drive.
    if you have managed to follow all that has anyone had the same sort of problem or anything i have missed to check
    thanks billy
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Check out various threads/posts on here for these symptoms...try Search section..punch in the query into the search section...information on other members experiences should come up...even mine....cheers
  1. Running problems with a 2.0 DTi
    By Jonathan1985 in forum Engine & Drivetrain
    Last Post: 11th April 2011, 11:19
  2. Vectra Running Problems
    By 11mallard in forum Vectra C / Signum Troubleshooting
    Last Post: 7th December 2010, 21:39
  3. Running Problems
    By Steve01 in forum Engine & Drivetrain
    Last Post: 22nd November 2010, 10:17
  4. 2.0T running problems
    By peteopc in forum Engine & Drivetrain
    Last Post: 27th February 2009, 23:20
