Thanks Thanks:  1
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: 3.0 V6 CDTi occasional limp mode...
    Regular Member fandango's Avatar
    Nottingham-ish
    Default 3.0 V6 CDTi occasional limp mode...
    Hi,
    The car has started to, very occasionally, go into limp mode.
    I start the car and it revs, then it sounds like something 'clicks', then it idles fast - the EML comes on (car with spanner through it).
    The car will barely rev over 3k rpm and the turbo will NOT spool up.
    If I touch the brakes, the revs return to normal, release the footbrake and the revs increase at idle - it's a fairly sharp jump of around 250 rpm (normal idle is 750 rpm). When the footbrake is depressed and I use the accelerator pedal, it does NOTHING - on either tickle, half or fully depressed pedal.
    Any idea what could be causing this?
    I have had a DTUK CRD2 box on for a couple of months which has been running absolutely fine (set at -1 then +1).
    This issue has happened both with AND without the DTUK box on.
    Any help/troubleshooting ideas welcome before I have to hand over some hard earned for some tech help at a stealers/specialists.
    Carl
    Nottingham-ish
    Forgot to mention that the car is Euro 3 (?) - pre-facelift, MY04.
    Full Member Big Sig's Avatar
    SOunds like its in limp home mode as you say, thats what causes the car not to rev. You need the codes read really.
    Nottingham-ish
    Cheers.
    Does the car keep a log of the codes, or does it need to be read when the car is in limp mode?
    It should keep a log but its better if its in limp mode. Mine does not seem to store the codes like it should, hopefully yours will.
    Nottingham-ish
    Cheers for that - looks like I'm off to get the codes read.
    Why can't engines be as simple as my first car - a 998cc Mini! I miss checking/adjusting plugs & points!
    EVERYWHERE
    Quote Originally Posted by fandango View Post
    Did it go into limp mode before you put the box on?
    Had the same problem myself.It was fine before I put the box on and then when I put the box on ,after a while, (few weeks) I used to get codes for 'boost pressure','EGR' (various),'MAP sensor' etc.Then I'd take the box off and still get the same errors.I'd then disconnect the battery for a while and all would be well again when reconnected..until I put the box back on,and then it would be fine for a while,and then.......You can see where this is going.
    Having the box on was really frustrating because it would be fine for ages and then a code would come up or it would go into limp mode,and now that the box hasn't been on for ages (still got one) I've had no real problems at all.
    Nottingham-ish
    It didn't go into limp mode until the box was on. Although the box ran for about 2k miles absolutely fine. Then one day, limp mode. So I took the box off and it was fine. I put the box back on and it was fine. Then limp mode. Then it was fine. Then it sporadically goes into limp mode with or without the box on.
    It did it again this morning. Driving along, approach traffic lights, EML light & limp mode. I limped to the next set of lights which, thankfully, were on red. Turned the engine off. Just before the lights changed, I started the car. Fine. And it was fine all the way in to work.
    I'm going to ring around a couple of places to get the codes read, once they're done, I'll compare them to your results DD.
    Nottingham-ish
    Well, it's now in permanent limp mode. EML light on dash is permanently on.
    Off to get codes read tomorrow. Will post up with updates as I have them.
    The fault codes generally remain readable for up to five key ignition starts
    However, if the fault is permanently showing then that makes life easier!
    However, this sounds like what mine did when I had accidently disconnected the MAF when changing the offside headlamp bulb
    It took a full hour, with the key out of the ignition, before the EMS reset
    Ironically, I had driven the car to the VX dealership and booked the car in
    It was on restarting it went away, so went back in, but they advised they would leave the booking open and if I didn't come back they would assume the warning was no longer present
  11. Thanks nickyb73 thanked for this post
  1. Cdti limp mode???.
    By steve1312 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2012, 00:46
  2. 3500 rpm then limp mode 1.9 cdti
    By lesron in forum Engine & Drivetrain
    Last Post: 23rd July 2012, 21:04
  3. Please help?? 1.9 cdti 150 limp mode p1125
    By rsvphil in forum Engine & Drivetrain
    Last Post: 24th September 2010, 13:43
  4. Signum 1.9 CDTi limp mode
    By doublek500 in forum Engine & Drivetrain
    Last Post: 6th June 2010, 22:26
  5. 1.9 cdti 150 limp mode
    By jeets in forum Introduce yourself.
    Last Post: 30th May 2009, 20:29
vectra c tuning box limp mode
vectra c 3.0 diesel limp mode and no fault codes
vectra c v6 cdti keeps going into limp mode
https:www.vectra-c.comforumshowthread.php90955-3-0-V6-CDTi-occasional-limp-mode
vectra c cdti goes into limp mode at idle
2006 vectra 3.0 v6 limp mode
3.0 v6 cdti vectra not revving over 3000
vectra c v6 revs moving going onto limp mode
vauxhall vectra v6 cdti limp mode
vectra c v6 linp mode
vauxhall signum limp mode on and off
3.0 v6 vectra limp mode
2004 3.0 v6 cdti vectra going into limp mode
