Thread: modified clutch return spring
    Regular Member denzilbud's Avatar
    cambridge
    Default modified clutch return spring
    just rang my local vauxhall dealership to get a price for the return spring and was given a price of just under £10.00 then i asked them how much to fit the part so i dint have to roll around the floor trying to fit it and seen as though its a 5 min job they wanted £75.00 to fit,what a rip off
    Regular Member Readster's Avatar
    Plymouth
    I think the expression is ''aving a giraffe'
    £75...
    Regular Member old cruiser's Avatar
    slough
    Yeah, what a rip off!! took me about 10 mins, I had had the lower panel off before so I new what to do at that time.
    Cheers Pete
    Wales
    In what way is it modified/what does it do or solve?
    Never heard of this before..
    Full Member Big Sig's Avatar
    It is a replacement as the other one can snap/fall out.
    cambridge
    has anyone fitted one of these and been dissapointed with how the clutch feels,imo they should have used a stronger spring
    slough
    Quote Originally Posted by denzilbud View Post
    I take it you've fitted it then? Have to say I find it fine on mine, not a lot different to what it was before I fitted it (if I remember correctly as it was last sept' I fitted it) , but at least it ensures the clutch pedal rises fully , to stop any excess wear on clutch and to ensure the cruise control works properly.
    Cheers Pete
    cambridge
    yeh fitted it in 5 mins only problem is it doesnt feel that much better does anyone know what would be involved in fixing the broken part
    cambridge
    or whats involved in changing the whole pedal unit over
  1. clutch return spring broken
    By wilson002 in forum Bodywork & Interior
    Last Post: 25th January 2013, 20:58
  2. Clutch Return Spring
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 14:47
  3. Fitting a clutch return spring
    By Reading1800 in forum Engine & Drivetrain
    Last Post: 10th June 2010, 18:01
  4. Clutch Return spring tension
    By Dazbaz in forum Vectra C / Signum Troubleshooting
    Last Post: 20th January 2010, 12:54
