Thread: 2.2 direct clutch misery
    newcastle upon tyne
    Thumbs down 2.2 direct clutch misery
    Hi guys, been having some problems recently, looks like a new clutch and flywheel job. Problem is started the car this morning and the engine managment light came on straight into limp mode . Fault code is (0420 unknow fault). Is this related to the clutch/flywheel ? because if i have another big bill the matches might have to come out.
    newcastle upon tyne
    Just looked at the fault code list, something to do with the cat just fitted a new one .
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Check the O2 sensors mate. If you had a new cat fitted then its part of the manifold and I'm sure both will have been moved.
    newcastle upon tyne
    It does smell a bit rich. Will do a search to find how to check them
    Vehicle : SRi
    Mileage : 137000
    What I mean is if you have got a new cat fitted and the problem came straight after then the plug might not be connected properly. I've got no idea how to how to check if the sensor is giving a false reading though.
    newcastle upon tyne
    i got the sensor out and back in real easy being very carefull not to contaminate. The wire coming from the sensor looks a bit twisted. In all very happy with they way i fitted the cat. The sensor was in a bad way as you would expect having covered 139k.
  1. Anger. Misery. Shame.
    By RobW in forum General Chat
    Last Post: 2nd October 2010, 00:27
  2. Thermostat misery!
    By K18 JRT in forum Engine & Drivetrain
    Last Post: 10th February 2010, 16:32
  3. 2004 2.2 sri direct clutch problem?
    By kenny1zero in forum Engine & Drivetrain
    Last Post: 9th June 2009, 21:34
  4. Shall we put him out of his misery....
    By BigMan in forum General Chat
    Last Post: 11th January 2008, 12:27
  5. 2.2 dti turbo misery!!
    By regishaunus in forum Engine & Drivetrain
    Last Post: 31st March 2007, 22:24
vectra sri direct clutch kit
vectra 2.2 direct clutch
