Results 1 to 3 of 3
Thread: Squeaking Noises
    Regular Member MrLOL's Avatar
    Wakefield, West Yorks
    Default Squeaking Noises
    My car has developed 2 different types of sueaking noises
    1) is quite loud and occurs when applying about 1/4 turn of left hand lock. Not dependant on moving or speed and only at this position so suspect its the steering rack.
    2) is a very faint squeaking, only audible with the windows open, but occurs when the front offside suspension is stretched upwards (such as turning left or when you've just jacked the car up) and you apply a sideways force to the car. Theres a particularly uneven spot at my local sainsburys that gets the suspension at the right place each time Squeaks only from the offside, and occurs whichever way you push the car.
    Its only happened since i cleaned under the arches so im guessing ive cleaned some grease out of somewhere that needs it
    But where ??? any suggestions.
    quick bump in case anybody has any more ideas before i book it into the dealers.
    Regular Member Readster's Avatar
    Plymouth
    I'd jack it up on blocks/ axle stands and start the engine and have someone turn the steering wheel to and fro while you carefully listen....
    It may seem a bit crude but, at least you can listen close up...
  1. squeaking noise
    By deepak in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2011, 17:20
  2. Fan motor squeaking
    By philc1210 in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 12:45
  3. squeaking from ns rear
    By paulf in forum Suspension, Wheels & Brakes
    Last Post: 10th February 2010, 21:53
  4. squeaking brakes
    By willoftoon in forum Suspension, Wheels & Brakes
    Last Post: 14th June 2009, 15:10
  5. aux belt squeaking.
    By john1 in forum Engine & Drivetrain
    Last Post: 21st April 2009, 20:32
