Page 1 of 7 123 ... LastLast
Results 1 to 10 of 65
Thread: any oil?
    Glasgow
    Default any oil?
    hi guys, im planning on doing an oil change very soon!
    morrisons are doing castrol 5L 10w-30 or 40 i think cant remember now, but its only £17!
    i think i remember reading somewhere it has to be a certain type of oil on the cdti engines?
    any ideas lads?
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Hi i would use GM spec 5-30 or if budget is an issue, GM spec 10-40 if changed regulary.
    have a look on fleabay you can get it cheapish... but another memeber gave a link out to national tyre IIRC, and they do oil and filter for not much more that the bits...
    worth a look.
    http://www.national.co.uk/order_oil.asp
    Glasgow
    i change the oil every 6k or so..
    but would be happy to leave it longer
    so i just search for gm oil then?
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    yep.. just lloked on fleabay, GM OIL, load to choose from, i would use 5-30 but its your call, if your gonna change it that often then the 10-40 would do, unless you have it chiped or a caterman box installed... i would use the 5-30 then!.
    i change it every 12m or 10k which i hit 1st, using 5-30.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    VX fully synthetic 5-30 here http://www.autovaux.co.uk/LoadPortal...bid=5&vnum=137 plus shipping.
    Glasgow
    is the castrol oil not better? i always though the GM oil was.. rubbish?
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    IIRC, the oil is made or called 'titan' which is rebadged for GM.
    as long as it meets the GM spec (GM-LL-A-025, GM-LL-B-025) it would be ok but i would stick with a leading brand. I used to use mobil 1 but it is expensive, i stick to GM's 5-30 changing it evey 12 or 10k, without fail.
    a little advice on oil...
    http://www.carbibles.com/engineoil_bible.html
    Glasgow
    Quote Originally Posted by dv8 View Post
    thanks very much mate,
    when i push my millage reset button it shows a can of oil with 26000 under it? is that when it needs its next major service? it seems to be every 30k miles my car has been serviced according to my service book.
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Quote Originally Posted by twaiter View Post
    WOW, i would never leave it that many mile between oil changes. It might be on something like an ECO service.
    I will admit, when I got my Vec-C I recall the INSP reading something silly, so after 12m, I got the 1st service done at VX, explained I would have it done every 12months, USING 5-30 (as they have a habit of using their 10-40) now my INSP now shows something normal dont recall but i think its 12k ish.
    Again it down to you. Some report it prevents sludge and other build-ups, others on the forum have company Vec's and stick to the ECO service schedule. I for peice of mind use the 12m rule.
    My neighbour has his own courier business, and uses Merc vans using Comma oil, most have covered 250k without any big issues, having them serviced every 20k/30k.
    have a search of the forum, it does offer alot of advice.
    Regular Member phykell's Avatar
    Apr 2008
    Cheshire
    Agreed - the standard, specified oil should be fine; and certainly if you're replacing the oil twice as often as the manufacturer recommends
