Results 1 to 10 of 15
Thread: Just serviced the Veccy - One hell of an air trap!
    Regular Member mishima's Avatar
    UK
    Cool Just serviced the Veccy - One hell of an air trap!
    I've just spent this morning servicing the Vectra as it's done 20K and needed doing. Everything went fine, as normal self services go - pretty easy. Sparked up at the end and the engine cut out, couldn't get it going again. Opened up the fuel filter that I had replaced and the fuel had been sucked out. This is what caused the cut out, it had sucked out and not been able to continue running etc.
    Anyway popped out got some fuel and then tried filling the pipes that hook up to the filter pot. It did start for a moment but then cut out.
    So I managed to get a tow round the corner, got the car into ignition and stuck it into 3rd gear. Got enough speed up for the engine to spark up and the fuel draw worked!! Pulled over, started engine up and drove home. Works fine now.
    So just a word of advice if you are going to self service, get your foot down on the throttle when sparking up!!
    Wales, UK
    lol - Glad its all sorted mate !!
    Regular Member m3ath3ad's Avatar
    Aug 2007
    Minehead
    did you get worried at one point? lol
    UK
    I did, esp after manually shoving diesel down the pipes and nothing was drawing. The air lock must have been quite tight!
    Aug 2007
    Minehead
    by the sounds of it, it was glad you got it going tho. you can relax now
    UK
    True Very glad. Only cost me £17.50 that service too. Cheap Castrol from ASDA and filters from local parts dealers !!
    Aug 2007
    Minehead
    Quote Originally Posted by mishima View Post
    barry bargin cheap to me
    Ashington, Northumberland
    Always prime the new fuel filter before fitting it You won't have that problem then
    UK
    Quote Originally Posted by GARY3306 View Post
    How do you prime the new filter?
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    never done one on the veccy, but didnt you used to have to discon the ignition coil to pump the fuel on older cars?
  1. Trap the cat
    By bobssignum in forum The 'Off Topic' room
    Last Post: 18th January 2011, 17:50
  2. Oil trap /CCV / Atmos mod, an endorsement
    By Derek Mc in forum Diesel Engine related
    Last Post: 18th November 2010, 15:03
  3. fli trap 12
    By baz2003uk in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2009, 22:46
  4. Speed trap on M1.
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2009, 18:26
  5. Speed Trap...
    By C19_CJB in forum Comedy & Humour
    Last Post: 8th August 2005, 11:17
