Thread: Jacking points
    swansea
    Default Jacking points
    Silly question time. Can you put a trolley jack under the normal plastic jacking points. First time wheels off tomorrow.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    yes you can. But would not do it..
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Course you can, but I would use a block of wood between the jack and the jack point though - do this all the time - its fine mate.
    I usually find a stronger more suitable point as I once crushed a jacking point doing this to the point that it was useless
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    You can but the stupid things do easily come out, as 3 of mine have come off
    Mileage : 000
    They are made form plastic and just push on. They can easily be damaged by the "foot" on a trolly jack.
    Regular Member KTM Chris's Avatar
    Nov 2007
    North Lincolnshire
    Plastic jacking points???? I've always used a trolley jack to remove my wheels, using the point under the sill pointed to by the little arrow on the side skirt. It's a good solid point.
    Mileage : 000
    Yep. The square tube hanging down from by the sill is made of plastic ( well some form of). I have seen makes in them, made by a trolly jack.
    Nov 2007
    North Lincolnshire
    Wow, I always thought that was steel!!
    Mileage : 000
    Quote Originally Posted by KTM Chris View Post
    So Did I.
  1. Front jacking points, and using axle stands
    By PeterVV in forum General Chat
    Last Post: 25th July 2017, 14:27
  2. jacking points
    By Kev_1664 in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 17:41
  3. Trolley jacking points & Axle stand locations?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2009, 14:26
  4. car jacking
    By John35 in forum General Chat
    Last Post: 20th December 2007, 10:22
  5. Signum MY 06 - Jacking points - Plastic !!!
    By omega2498 in forum Bodywork & Interior
    Last Post: 30th November 2006, 00:24
side skirt jacking point vectra removal
https:www.vectra-c.comforumshowthread.php90850-Jacking-points
jacking point on 2006 vectra
