Thread: Car and soanner when cold
    Aug 2009
    NORTHAMPTON
    Default Car and soanner when cold
    Hi All,
    I recently purchased a 2.2 SRI DTI on an 02 plate private sale.
    On a cold start i get the car with spanner through it image on the dash, it goes off after about 10 seconds.
    Once the car is warm and you restart, it doesnt show and can stay off for the rest of the day. (i brought the car without seeing it from a cold start, the seller said he just nipped out to put petrol in it, now im thinking he warmed it up).
    Should the car with spanner be showing when its cold?
    I also dont get the glow plug display before starting up like most diesels, infact i havent seen it once is this normal?
    It does seem like its using a bit more diesel than it should be, but not much.
    Has anyone got any ideas before i take it to a Vauxhall garage?
    Thank you
    11 Post(s)
    Quote Originally Posted by monkeydribble View Post
    Hi All,
    I recently purchased a 2.2 SRI DTI, the seller said he just nipped out to put petrol in it
    Hopefully that was a typo?
    Aug 2009
    NORTHAMPTON
    LOL Oh yeah i meant diesel
    Regular Member KTM Chris's Avatar
    Nov 2007
    North Lincolnshire
    Isn't that the reminder that a service is due? Does it come on again when you switch the ignition off and take the keys out?
    Regular Member madman's Avatar
    nottm
    my 20dti does it when cold, runs fine tho . might be glowplug fault, i replaced the glowplug relay but it still lights up , did get a fault reading for the EHPS and the body control module. but while everything runs fine i'll leave it
    Aug 2009
    NORTHAMPTON
    Cheers guys, dont think its a service reminder i think that shows as "INSP".
    It goes off after about 10 secs, and if i restart straight away it comes on again. but after a 10 minute drive it wil stay off for pretty much the rest of the day..
    Has anyone ever had their glow plug light come on? i didnt know if perhaps my glow plug 'warning bulb' in the dash had gone??
    West
    Glow plug light only comes on around 5*c mate, you could try whipping the coolant sensor plug off & see if light comes on & how quickly the motor fires... you will get an eml with the plug disconnected until you connect back up
    Jul 2009
    Birmingham
    I have been doing so reading about this kind of problem as I am experiencing something similar except worse.
    My car just won't fire up now. The fuel filter has been changed as I thought that it may have been the problem. Now when I try and start my car it gives me the same warning light and just splutters between 1000 & 2000 rpm even when foot is to the floor. The most worring thing is that the amount of smoke coming from the back is enough to draw a crowd from the neighbours.
    The common problems I have read are about leak off pipes and injector seals. Its all to do with air getting into the system I think. Will be getting a VX mechanic to have a look I think as it appears to be common place with the VX DTI engines.
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  3. No Cold Air
    By dhwigston in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2009, 18:52
  4. It's Getting Cold
    By slipperysam1984 in forum General Chat
    Last Post: 2nd November 2009, 13:34
  5. Not used to the cold??....
    By Pinman in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2007, 13:03
