Results 1 to 3 of 3
Thread: signum..grinding noise from rear
    bromsgrove
    Default signum..grinding noise from rear
    hi all,had my signum for about 12 months now and recently,(approx 3 months ago),noticed a grinding/scraping noise from both rear wheels,my first thought was a brake or disc issue,but these seem to be o.k,the discs are worn but no lines to indicate deep scoring also the noise is always present not just under braking(which i would expect with pad/disc wear)had the mot and i was given an advisory note that both rear bearings are worn,
    is this the cause of the grinding/scraping noise?,if so is it an expensive job?
    model is an 05 signum elite with 19" vxr alloys,these came with the car when i bought it,(not my first choice as i understand big alloys can damage bearings),
    thanks in advance for any help/advice you may be able to offer me
    Jul 2009
    lanark
    worth having a really really close look at inside pads for wear,
    they are renown for rear brake calipers sticking are the veccys
    Mar 2007
    Beaconsfield, Bucks
    Had the same problem as you. Mine were as jim says, outside was fine, inside was bad. new discs, pads and sliding bolts sorted it out a treat.
  1. grinding rubbing noise
    By coooky in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2011, 09:49
  2. grinding noise coming from rear wheels
    By pud wayman in forum Suspension, Wheels & Brakes
    Last Post: 21st June 2011, 07:27
  3. Grinding noise from the rear breaks
    By freddy in forum Suspension, Wheels & Brakes
    Last Post: 20th June 2011, 18:07
  4. Strange grinding noise coming from rear wheel
    By sproket in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2009, 22:04
  5. Grinding Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 10th October 2006, 07:52
