Results 1 to 10 of 23
Thread: Radio reception?
    Regular Member monkeez's Avatar
    Apr 2008
    North East
    Default Radio reception?
    I've just installed my new Pioneer AVH-P3100DVD
    I havent yet got the PC99-X45 wiring harness and the patch lead needed for the steering controls.
    The radio reception is crap - only picking up Radio 1.
    Could the fact that i havent got the above cables have anything to do with this?
    Feb 2006
    Dorset
    Sounds like the antenna is not getting its 12v feed for the signal amplifier
    Apr 2008
    North East
    how do i sort that out?
    Apr 2008
    North East
    just had another look at it.
    I can get some FM stations by manually tuning it (wont find on auto search), but not the best reception.
    I can just make out the MW ones but very faintly.
    Apr 2008
    North East
    sorry to be a pain, but how can i fix this?
    Feb 2006
    Dorset
    In the Main power plug that goes into the radio is a wire coming off i think its a blue with red trace thats the power supply to the ariel , you need to connect up the power antenna wire to it so when the radio is on its gettng a 12v feed to the ariel amplifier which is built into the base of the antenna .
    Is your car a full or half can-bus ?
    Apr 2008
    North East
    it's a half can bus (3 buttoned steering wheel)
    In the manual for the unit, its says that the 'blue/white' wire on the units loom is to be connected to auto-antenna relay control terminal
    So do i need to connect that up with the blue/red wire on the car?
    Feb 2006
    Dorset
    If the blue red is the correct wire (double check) then yes , you need to connect them together and that will supply the antenna amp with power when the radio is on
    Apr 2008
    North East
    nice one Dennis, i'll try it later.
    I'm pretty sure that the blue/red and grey/white wires on the cars loom arent connected up to anything on the units loom.
    Feb 2006
    Dorset
    IIRC one is to switch the screen , you know when you switch on the radio and the date disapears and the other is power for the antenna , from the age of your car im pretty certain its the blue red trace .
  1. radio reception
    By fiend61 in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2013, 10:28
  2. radio reception
    By derby4life in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2009, 17:57
  3. CD 30 Radio No Reception on AM
    By Tomkid in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2009, 14:44
  4. radio reception really bad
    By kev1983 in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2008, 19:47
  5. Radio reception
    By victor in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2007, 11:39
