Thread: Egr or boost sensor ??
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default Egr or boost sensor ??
    i have recently cleaned the boost sensor on the inlet manifold and im sure the egr is clean, im getting (mainly from cold) a quick short sharp and snappy pull back or sudden loss of boost or power! hard to explain realy but its a quick on/off must be boost type related any ideas folks ??? (1.9 cdti 150) the swirls are well worn but all connected and working.
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Id check the large pipes and the smaller vacumm pipes for splits
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    this engine is in 1000% top condition and is as new, so im very confident its the sensor or egr starting to fail, i could do with a sensor to try to eliminate it.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    problem now solved!!, took the egr off and it was clean as i thought but the plunger-spring valve was slightly open so i worked it by hand and it stuck open, as i said above it was cleaned about 4 weeks ago so it just goes to show it can happen, cleaned with wd 40 to get it working again.
  1. boost sensor on the 120
    By SarahP in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 22:25
  2. Boost Sensor & 10K Boost
    By hebdendave in forum Diesel Engine related
    Last Post: 13th February 2011, 17:43
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
