Page 1 of 7 123 ... LastLast
Results 1 to 10 of 65
Thread: Clunking door stay.
    Tyneside
    Angry Clunking door stay.
    Anyone ever had their door stay making a clunking noise as it goes over the ridges on the arm? Mines being doing it for a while, but I just ignored it. Anyone got a price for a new one or a part No?
    Regular Member sri andy's Avatar
    Apr 2009
    Lancs/Manchester
    This isnt that un-usuall on a lot of cars. The check strap itself is seldom to blame, its usually the bolt holding the strap to the pillar is loose or the two nuts holding the strap to the door frame are loose....two things to check before you order one. HTH
    Mar 2007
    North East
    The bolts on both my Signum and Vec door stay worked loose. Bit of thread lock and never had the problem again.
    Tyneside
    I'll check them first although I think I checked them initially, been doing it for so long.
    preston
    The clunking noise is the nylon rollers that roll over the shaped door stay, The roller stops rolling due to lack of lubricant and a flat starts to emerge on the roller itself and hence it doesn't roll but clunk, you can only see this if you take the unit off as its part of the stay thats inside the door. I took mine off and filed it round again, made it a bit better but replacement obviously better. will submit a piccy of stay if you wish to show you the roller.
    Tyneside
    Quote Originally Posted by bygumlad View Post
    Explains a lot, lubricating it made it worse in fact. I'll see how much it is from VX then see if there's a local scrappy where I can get one. Pic would be good please mate
    Is it easy to get to once the door trims off?
    Plymouth
    I also have the same problem.... greasing worked for a while... but now its getting worse..
    Its only on the drivers door.
    Tyneside
    Same here mate.
    East Midlands
    Have you checked to see if the bolt is loose,first before you buy anything cus it's usually the problem 9 times out of 10
    Tyneside
    The bolts are fine on mine. It's as bygumlad mentioned when the roller passes over the door stay it makes the clunk as the stay has a profile on it to hold the door open.
  1. How2 fix clunking door stay
    By luke4487 in forum Bodywork & Interior
    Last Post: 29th January 2013, 19:53
  2. clunking door strap
    By redross555 in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2011, 12:52
  3. programing a new door stay assembly
    By neil0748 in forum Troubleshooting
    Last Post: 12th December 2008, 02:40
