hi guys what does this mean i know its injector valve voltage converter system malfunction but what is it and can any one tell me the part number for the hp pump suction valve kit many thanks in advance
Pm MTC, I know he for one had the hp suction pump done.
cheers celes i have just changed all injectors and the car is still the same so it looks like a strip down to take the valves out the car still runs but is a pig when it is cold on low revs but ok on high revs do u know what goes wrong with the valves and is it clearly visable on removal of valves
Does your engine knock when going uphill in 4th at 1500rpm? Mine does if I apply a substantial amount of throttle...sounds like a bag of spanners being kicked around
I'm not sure what needs to be checked on the valves themselves...maybe corrosion? I emailed autovaux about the repair kit for £84...I'll see what they have to say about it.
cars now stripped down not too bad of a job but a lot of parts to remove will order parts on tuesday cant see much wrong with the valves but i guess u wont as there a electronic solonid valve
