Thread: fault code p1216
    Regular Member 30ltr nutter's Avatar
    dunstable
    Default fault code p1216
    hi guys what does this mean i know its injector valve voltage converter system malfunction but what is it and can any one tell me the part number for the hp pump suction valve kit many thanks in advance
    Full Member Big Sig's Avatar
    Pm MTC, I know he for one had the hp suction pump done.
    dunstable
    hi big sig the only mtc i can find is a new member with a gsi so i guess thats not him
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    dunstable
    cheers celes i have just changed all injectors and the car is still the same so it looks like a strip down to take the valves out the car still runs but is a pig when it is cold on low revs but ok on high revs do u know what goes wrong with the valves and is it clearly visable on removal of valves
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by 30ltr nutter View Post
    Does your engine knock when going uphill in 4th at 1500rpm? Mine does if I apply a substantial amount of throttle...sounds like a bag of spanners being kicked around
    I'm not sure what needs to be checked on the valves themselves...maybe corrosion? I emailed autovaux about the repair kit for £84...I'll see what they have to say about it.
    dunstable
    cars now stripped down not too bad of a job but a lot of parts to remove will order parts on tuesday cant see much wrong with the valves but i guess u wont as there a electronic solonid valve
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Hope you get it sorted mate. It's a very good car when working well. How many miles has yours done, if you don't mind me asking?
    dunstable
    Quote Originally Posted by Celes View Post
    46.000 miles not a lot for the type of engine and to have these problems so early in its life span
  1. Fault Code Help
    By rmg1 in forum Y & Z30DT Specific
    Last Post: 3rd October 2012, 21:12
  2. fault code on vec c 1.8 sri please help
    By gavs-sri in forum Engine & Drivetrain
    Last Post: 10th April 2012, 21:52
  3. Fault code
    By bellsjoe in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:24
  4. is this a fault code
    By hoochydady in forum Troubleshooting
    Last Post: 23rd February 2010, 18:03
  5. Help with fault code,
    By robwilson69 in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2009, 21:57
P1216 signum
foutcode p1216 opel
p1216 opel
