Thread: keep getting msg saying parking light
    Regular Member slick91's Avatar
    Jul 2009
    Newcastle
    Default keep getting msg saying parking light
    i keep getting a msg on display reading "parking light" even though i have no lights on and when i switch them all on and check them including braking lights nothing is out plus sometimes ill drive over a a hole on purpose to make car bump a little and it goes away as if ive a loose connection or something????? plus ive tried to get rid of service warning and cant seem to get shot of it??? any help please?
    Aug 2009
    LEEDS
    i once bought some cheap side light bulbs from ebay and they caused the Parking light warning to come on. i then bought some better quality ones and the warning dissapeared.
    if your warning light dissapeares when you hit bumps maybe try clean all contacts on bulbs and connectors
    Jul 2009
    Newcastle
    Quote Originally Posted by shearzy View Post
    ive checked all the connectors well rear ones anyway and they are clean free from dust or erosion??? cheap bulbs eh? now theres a thought although that would make it stay on all the time wouldnt it?
    11 Post(s)
    Quote Originally Posted by slick91 View Post
    The bulb monitoring circuit checks all the bulbs (excluding dash and numberplate bulbs) regardless whether they're switched on or off.
    Have you got Check control which tells you the exact bulb that has failed and displays it on the stereo display, or only the light in the speedo cluster that only tells you a bulb has failed, but not which one?
    I suggest you check the connection for the front bulbs as well.
    Also, if a brake light fails, then the lower of the 2 rear side lights takes over the role of brake/tail light.
    Mileage : 000
    I think that in a day or Two you will see one of the bulbs has "blown" I had this with mine. It was telling me there was a "blown" sidelight bulb. But I could see nothing wrong. Then a few days later. There was one on the right that had gone out.
    Minehead
    mine stays on all the time because i fitted led's to the front sidelights
    with 'normal' 501 bulbs all is fine, and the message goes away.
    i know you can put a resistor in, just dont want to.
    Regular Member SignumPhil's Avatar
    Luton, Beds
    It usually means the filament is going in the respective bulb. Last time, it kept warning for weeks before it actually failed.
    My offside parking light has been warning on and off for weeks, usually when you go over a bump. It hasn't done it since I blew a tyre on the M4, funnily enough..........
    Phil
    Jul 2009
    Newcastle
    Quote Originally Posted by ed taylor View Post
    Quote Originally Posted by SignumPhil View Post
    Phil
    cheers guys hey phil thats exactly what mine does although not everytime,,well im speachless i would of never of thought of that ill keep an eye on it, i did have one blow last week so we'll see which one goes next hopefully it wont keep happening if it does ill try more expensive bulbs next time, cheers guys
  1. Parking light
    By rob123 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2010, 20:31
  2. Parking light/side light
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2009, 11:14
  3. Parking light check bulb light on and wont go off
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2008, 12:03
  4. parking light
    By dan1983 in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2007, 21:37
  5. Parking Light?
    By sph73 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2007, 18:32
vauxhall vectra parking light warning
vectra c parking light
parking light vectra c
https:www.vectra-c.comforumshowthread.php90756-keep-getting-msg-saying-parking-light
parking light vauxhall vectra
where is the parking light on a vectra
vauxhall astra parking light warning
vectra c parking light bulb
vectra c parking light warning
astra parking light message
astra parking lightparking light vauxhall zafiraparking light zafira bparking light on vectravectra parking lightparking light zafiraparking light on vauxhall vectraastra twintop parking light warningparking light vectravectra parkong lightastra twintop displaying parking lightvectra parking light bulbastra twintop parking light staying on
