Results 1 to 2 of 2
Thread: Heavy clutch
    Chelmsford
    Default Heavy clutch
    I'm sure the clutch on my Vec is heavier than it used to be, it's certainly a lot harder to press than the pedal on newer models.
    Any way of making the pedal lighter, without replacing the whole clutch? Years ago I replaced the clutch cable on my mk3 Astra which made a huge difference, anything similar I can do with a hydralic clutch?
    Also got the usual problem of the return spring not pulling the clutch back up properly so the cruise control doesn't work... How easy is it to sort? Is there a how2 about?
    newcastle upon tyne
    hi mate my clutch has been heavy for a while now and last week noticed it begining to slip for the first time. Cant complain really having covered 139k on the original.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. vec b heavy clutch
    By twaiter in forum Engine & Drivetrain
    Last Post: 27th March 2011, 23:47
  4. Both of them (pic heavy)
    By m111kan in forum Quick Photo Album
    Last Post: 4th April 2010, 12:32
  5. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
vectra c heavy clutch
