Thread: cdti 150 struggles on tick over
    Regular Member robk6112's Avatar
    Halifax
    Default cdti 150 struggles on tick over
    My cars has just started to struggle to tick over when cold especially on start up. It is due a servide this month but would this be the cause as no faults are showing? Any ideas
    Regular Member Readster's Avatar
    Plymouth
    May be as quick as anything to book a VXtech2 check to see which sensor or whatever is playing up Rob.
    May 2006
    scotland
    Could be the EGR valve that needs a clean. It may not be bad enough to trigger a fault code but maybe bad enough to effect the idle. I'd add a good fuel cleaner to a full tank of Diesel and boot it up an down the Mway in 3rd at 70mph for a good 4 or 5 mins to clean out the cobwebs.
    Halifax
    Thanks ill try some millers tonight. It cant be the egr valve though as its almost new.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    never look a gift hoarse in the chops!!, i cleaned my egr out, four weeks ago and i had a major engine miss-fire today, it was the egr slightly open and the valve/spring stuck/sticking that was the problem. it ran on tickover ok but when reved up sounded like a bag of ****!!!
    lanarkshire
    just a thought try a cable tie onto 3rd injector or all injectors wiring
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. Tick tick tick Crunch
    By sickboyjay in forum Engine & Drivetrain
    Last Post: 18th April 2011, 14:25
  3. 2.2 DTi Struggles to start...
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2009, 17:53
  4. 3.0 V6 CDTi tick over noise
    By scwilson in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2008, 18:14
  5. Tick Tick Tick BOOOOM
    By staticbob in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2007, 15:42
