Bloomin pheasants! knocked in fog and blew bulb not sure how it goes back in or how to take it out properly anyone any thoughts?
Jack the car up firstly , then look underneath the fog light housing you will find a cap that unscrew,s remove this , then feel inside you will come across a spring saddle clip
compress and release this , bulb will then be loose comes with a small wire connection remove and replace.
fitting the reverse of previous statement
hope this helps
and still loving it
if the fog surround bit is broken ,you will be better off removing bumper ....if just bulb then its what Bob said HTH
Chheers for that better get the overalls on and have a look. The surround has moved a bit dont know if its completely knackd or not hope not!
im gonna have to get some of those fog surrounds for my veccy
