Results 1 to 3 of 3
Thread: swirl actuator problem
    Nov 2007
    luton
    Default swirl actuator problem
    alright guys ive got a problem wiv my vectra 1.9 cdti 150, ive changed the swirl actuator & the egr valve afew days ago, but the car still has a slight judder when stationary & it holds back, not giving me a quick response when i put my foot down but when it goes over 2000 revs it goes like a bullet, my mpg has gone from 44.5 to 36.7 local driving. can any1 help please
    i also changed my back brake pads & handbrake cable since then i get a funny noise (like sumthing is loose coming from the rear passenger side wheel when i go over bumpy roads or road humps, ive check the wheel, brakes etc cant find nothing, ive turned the wheel hub & got a little click when i was turning it? could it be the wheel bearing?
    its very annoying!!!!!!!
    Jun 2007
    livingston
    Hi,
    Regarding the noise from the rear of the car, I had a similar problem on my 2006 2.2 direct petrol Vectra which turned out to be the nearside front suspension drop link , one rubber had become dislodged on one of the joints and dryed out , although the problem was at the the front of the car the noise seemed to come from the back of the car when going over road humps or bumps, this may be the problem you are having.
    Nov 2007
    luton
    hello mate thanx for the infor my issue was the off side rear brakes FAULTY, changed them no noise
    regarding the juddering ALL SORTED ITS COME BACK TO LIFE AGAIN! No juddering amazing power & awsome MPG, All i did was add forte diesel treatment in the diesel filter then I gave the car a good hammering 1-2-3 gears high revs MISSION ACCOMPLISHED
  1. Swirl actuator
    By carl78 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 11:44
  2. Swirl pot actuator
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 21st November 2009, 01:00
  3. swirl actuator problems
    By ziggi in forum Diesel Engine related
    Last Post: 28th August 2009, 11:47
  4. Swirl Actuator Problem... or not?!
    By djr69uk in forum Engine & Drivetrain
    Last Post: 2nd May 2009, 21:18
  5. Swirl valve actuator
    By oxenburger in forum Engine & Drivetrain
    Last Post: 24th March 2009, 19:17
