Thread: Vec 3.2...water on passenger side foot thing...
    asdasd
    Default Vec 3.2...water on passenger side foot thing...
    basically cleaned it a couple times..I always thought someones dropped water there or something..But theres alllways water there..
    Passenger side footwell if thats what you call it...Where the passenger would put his feet...
    Why is this happening? Is there a fix? its basically soaked all the time
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    This crops up on a regular basis here on the site, what you need to do is:
    "Copied from another post by Duncan"
    Under the wind deflector (black plastic thing at the bottom of the windscreen on the outside and there's a flap on the passenger side to access it). Check that you haven't got a build up of leaves etc... in the area under the wind deflector. If you have then locate the couple of drain holes that are there and dig out/push through any gunk that is blocking them.
    Basically the drain holes can get blocked and the any water build can result in ending up in the passengers footwell as you describe.
    HTH,
    Bri.
    Jul 2009
    lanark
    Quote Originally Posted by brifen View Post
    HTH,
    Bri.
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    where your pollen filter goes there is a drain hole if thats blocked then thats where your water is coming from.
    Regular Member old cruiser's Avatar
    slough
    And don't forget to check the one on the drivers side while you're at; this one is not as accessible as the passengers side and without removing the plastic scuttle panel you can open up an old wire coat hanger and feed it through and down into the drain hole via the scuttle panel vent holes as it were HTH
    Cheers Pete
    Or use the search button
  1. Wet Passenger Side at Foot area
    By akeem in forum Bodywork & Interior
    Last Post: 9th November 2012, 10:29
  2. water in passenger foot well
    By crayon in forum Bodywork & Interior
    Last Post: 28th January 2011, 13:31
  3. water in passenger foot well
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2010, 16:39
  4. There’s water in the passenger foot well
    By Tadpole in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 22:36
