Thread: Strange ECC behaviour
    Melbourne, Australia
    Default Strange ECC behaviour
    Hi everyone,
    I posted this ages ago on Vectra-Sport, before I realised all the C owners were here... Well it's getting cold in the mornings again and this problem is annoying me again.
    Has anyone noticed this (or do I have a problem)?
    If I turn the car on, then immediately press both front and rear demist buttons (on the climate control unit), the rear demister turns off after a couple of seconds. It seems to be that as the fan builds up speed, the demister cuts out.
    I wonder if it's a current draw protection thing?? The rear window demist will pull about 30 amps and the blower motor on full chat in a sealed car will pull at least that..I wonder if VX designed it that you couldn't run both at the same time..
    I'm off for a play..
    That shot me down in flames..
    The ECC in mine just let both run for 5 mins till the rear screen was clear..All the car did was pick the rev's up slightly as the electrical load was applied..
    In the pre-canbus day's i'd have said the relay was at fault, but are they still fitted??
    Regular Member Ozz's Avatar
    Sydney, Australia
    Hmmmm, I had both the front & rear demisting away on Saturday evening & had no probs.
    Quote Originally Posted by stevedee3
    I've had something similar, but not specifically in conjunction with the front demisters.
    I'll start up the car on the drive, turn on the heated rear window/mirrors and by the time I've got off the drive I've noticed that they've turned off. I turn it on again and it then stays on. Doesn't do it every time, but often enough to have noticed it.
    I've no idea what it may be, but as it's a small 'niggle', I've never bothered too much about it.
    OK, here's my submission for world's longest post...
    Quote Originally Posted by Ozz
    Quote Originally Posted by Gsi3.2
    When the "weird behaviour" happens, the rear demister will turn off almost as soon as it was turned on. It's stays on just long enough for you to look away... I'm not talking about the 15-20 minute timer. It only seems to happen when the car has just been turned on.
    I think you may be on the right track, Gsi3.2. I imagine the way to make the ventiliation fan draw the most current is to have it static and then ask it to go at maximum speed. Similarly a cold demister probably draws a large current. Maybe doing both at once causes such a large current draw that the ECC unit has to switch something off?
    That sounds like what I'm talking about. I find myself later wondering why the window and mirrors haven't demisted.
    It took me a while to work out what was going on. I thought I just hadn't pushed the rear demist button properly until I took a closer look.
    So, to recap (and just to make this post even longer ), the procedure is:
    1. Cold (cool?) car (been off for at least ~10 minutes)
    2. Turn ignition on
    3. Immediately turn on front and rear demisters. Don't take your eyes off the indicator LEDs
    4. If the "weird behaviour" occurs, the rear demister will turn off within a second or two.
    The following things don't seem to make any difference:
    • Whether the air conditioning commpressor is on or off ("Economy" mode)
    • Whether the headlights are on or off
    • Whether the seat heaters are on or off
    Yep, I don't always notice it straight away. Often 10 mins into my journey when I notice the mirrors haven't started to clear.
    I rarely use the front demister feature (only in cold winter really) so it's not that that causes it. I haven't done any other 'tests' to see if it only does it when certain things are turned on as it's never been a big deal to me - I just push the button again! lol
    It just seems to be if you turn on the rear window/mirrors straight after you start the car. If I don't do anything, then turn it on once I'm on my way then it stays on.
    Warwick
    So its not just mine that this happens to?
    In the cold weather I would lean in and start the car and turn on first the windscreen defrost. Then turn on the rear screen/door mirrors before attacking the ice on the windscreen. I noticed that when scraping the side windows the rear demister light had gone out. Press it again and it stays on.
    I watched this on other days and it always turns off after a few seconds. It always stays on when pressed a second time.
    I haven't a clue why it does this.
  1. Strange idle behaviour
    By jaap in forum Engine & Drivetrain
    Last Post: 7th September 2010, 11:47
  2. Strange engine behaviour
    By WilliamLX in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2010, 13:50
  3. Strange behaviour
    By martind511 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2007, 20:59
  4. Strange Behaviour
    By spoons in forum General Chat
    Last Post: 10th September 2007, 21:28
  5. Strange behaviour from Car
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2007, 17:49
