Thread: Confused
    Aug 2009
    preston
    confused Confused
    Can anyone help, my 05 vectra is not very well, the alarm goes off usually at night, then in the morning the car wont start it just clicks, I wait 5 mins then it will start. My bulb replacement light keeps coming on and off, when it is on the boot wont open, the rear wiper does not work and the brake light on the boot does not work. Sometimes I can get them working if I slam a rear door. Has anyone had any of these problems?
    Regular Member steveked's Avatar
    Dec 2005
    Newcastle
    Battery on its way out maybe? does the trip computer reset and stuff ? or a wiring fault?
    Regular Member Factory Pilot's Avatar
    Leics
    Got a similar issue although not as serious with mine currently. Is it an estate vectra?
    Clicking why trying to turn the engine over maybe the starter solenoid when the battery cannot supply enough voltage to the starter motor to turn the engine over. eg flat battery
    Mine was doing this as the alarm was also going off for no apparent reason. Sometimes fully, but I also noticed the alarm would flash, but not sound, so still using the battery up.
    I removed fuse 23 for the rear alarmed glass and the alarm no longer sounds randomly, however I now get "Safeguard" appearing on the interior dispaly whenever the ignition is turned on. But have yet to take it to Vauxhall to rectify the problem.
    Aug 2009
    preston
    Its a hatchback, I am thinking it maybe a fault in the fuse box in the boot. Does anybody have any knowledge on this area
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    have you made sure that your battery terminals are on tight
    Aug 2009
    preston
    Default Problem solved
    My car is now fixed, it was a wire on the starter motor that was loose, it has been nipped back together and everything works, How can something so small and simple cause so many problems?????
  1. Confused!!!
    By tammyman09 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 15:53
  2. How confused am i
    By 21_03_sxi in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2011, 22:36
  3. Confused???
    By monty2000 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 11:31
  4. I'm well confused now.
    By shan in forum The 'Off Topic' room
    Last Post: 28th January 2009, 10:12
  5. Confused About Car Key
    By Hynzy in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2009, 22:54
