Thread: Lumpy Kangaroo
    Default Lumpy Kangaroo
    Hi
    Only had mt Vectra 1.8ls for a week, i have noticed a slight lumpyness when accelerating. Also when moveing in traffic with fairly low revs when i just touch the throttle it seams to lightly "kangaroo". Is this normal for the engines, if not any ideas??
    Dunno about Kangarooing as such but the vectra engine does have a noticable flat spot on the lower revs, yours sounds more like a fault though, I would take it to VX for a look....
    In slow moving traffic are you using the throttle to move ? or are you just bringing the clutch up and using the engine torque to move at idle ?
    only just on the throttle at the point where the revs start to pick up. Under hard acceleration it just seams slightly lumpy with the power delivery.
    My 2.0T will kangaroo a bit if I'm going slowly and have little revs (clutch fully up) - I think a lot of other cars will do the same in the same circumstance. I think it's normal - answer being to dip the clutch a bit if you're moving slowly.
    HTH
    Regular Member C19_CJB's Avatar
    Beverley, East Yorkshire
    Quote Originally Posted by daznsaz
    Hi
    I have noticed the same 'kangarooing' in traffic with my LS...usually does it just over 1000rpm.... does get on your nerves but you get used to just dipping the clutch a little bit to overcome it.
    I haven't noticed any lumpyness when accelerating though... might be worth getting that checked out?
    HTH
    Chris
    dont know about the petrol engines but on the derv cars its down to the drive by wire setup that split second delay where the throttle doesnt know what to do on quick on off applications easiest solution as said is to dip the clutch HTH
  1. First Start Kangaroo
    By coolcatkelso in forum Engine & Drivetrain
    Last Post: 28th August 2012, 17:08
  2. kangaroo, egr and pipes HELP!!
    By madas in forum Vectra C / Signum Troubleshooting
    Last Post: 29th April 2012, 17:13
  3. Kangaroo Juice !!!
    By Fireyfella in forum Engine & Drivetrain
    Last Post: 8th October 2009, 05:33
  4. Kangaroo under the bonnet??
    By Steves-Vec in forum Engine & Drivetrain
    Last Post: 10th June 2009, 20:15
  5. Does the 2.2 kangaroo?
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2007, 20:22
opel Vectra c car kangaroos site:www.vectra-c.com
