Thread: USB TV Tuner
    Regular Member Damian's Avatar
    Market Drayton
    Default USB TV Tuner
    Does anyone use (successfully) a USB tv tuner in their laptop when out and about. I was looking for one for camping and was hoping to use the little aeriel they come with, but have read so many mixed reviews
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    why not just use the iplayers i.e. bbciplayer,itvplayer,4od and such its easier and cheaper
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Quote Originally Posted by Damian View Post
    They work well as long as you have a very good signal, to use the short antenna supplied you really do need a good signal to get anything worth watching, IME most times for decent pictures it will need connecting to a proper arial system. I assume we are talking about a digital type, in which case its possible that signal strengths around the country will improve substantially as regions get switched completely over to digital. Currently with that tiny supplied stick antenna you will be lucky to get a picture unless your near to the transmitter.
    Regular Member Robbie69's Avatar
    I use mine with a portable aeriel you plug into the mains. Works a treat!
    Market Drayton
    Quote Originally Posted by simplesi View Post
    So just need to find a campsite with a good low contention broadband link then
    Regular Member LJ sxi-nav's Avatar
    Winchester
    Quote Originally Posted by 67688c View Post
    You need to have a REALLY good signal to get anything at all. My USB DTV tuner only works at home if I connect it to the main aerial (kinda defeats the object of it!) I've never got it working from the short aerial supplied.
    Robbies idea of a portable, amplified aerial should work ok; or how about getting hold of a caravan system - the omnidirectional aerials you see on many caravans (possibly coupled with an amplifier) should provide an easy solution...
  1. In Car Tv Tuner £25 Posted
    By crazy-dee in forum General items for sale
    Last Post: 20th March 2011, 20:27
  2. Tuner Bolts
    By yoclick in forum Handling & Braking
    Last Post: 27th November 2010, 18:06
  3. Diesel Tuner Box for sale
    By Rikkiola in forum Parts for sale
    Last Post: 24th March 2009, 00:37
  4. 2.2 DTi Tuner Prices
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2007, 09:02
  5. Diagnostix Tuner
    By Damian in forum Diesel Engine related
    Last Post: 23rd October 2005, 18:54
