Results 1 to 2 of 2
Thread: zafira 1.9cdti 120 eml on
    Regular Member sidturbo's Avatar
    burnley
    Default zafira 1.9cdti 120 eml on
    hi all not been on here for a while since purchasing zafira but thought u guys maybe able to help.
    while sitting in traffic in 36degree heat in france recently the dreaded car/spanner light comes on, when i turned the car off a code came up in the display (insp4), after reading through the owners manual i found out that it is sensing water in the diesel filter and now the car is running lumpy at idle and has a slight chug around 2000 rpm.
    when the car cooled down restarted and the light went off but has done this a couple of times whilst stuck in traffic.
    would water in the bottom of the filter cause this rough running?
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Water in the fuel is never a good idea. Long term it can cause all sorts of damage. Water in Diesel doesn't happen so much now, due to high turnover of Diesel in the UK. You possibly could have filled up at a garage that was on the dregs in its tanks and got contamination in your tank. The filter will have caught it, but fuel supply to the engine may be hindered, hence your problems.
    You do need to get this drained.
  1. Zafira B
    By Exclusive BV in forum General Motoring Chat
    Last Post: 11th November 2012, 10:17
  2. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  3. my zafira
    By DAVIDD88 in forum Vehicle Diaries
    Last Post: 6th April 2012, 16:23
  4. zafira 1.9cdti 120 dpf trouble
    By sidturbo in forum Engine & Drivetrain
    Last Post: 4th July 2009, 11:35
  5. New Zafira VXR
    By vectravirg in forum Non Vectra C/Signum Album
    Last Post: 5th November 2008, 14:52
astra 1.9cdti spanner light when stuck in traffic
