Thread: Control Arm
    Jul 2009
    Waterford
    Default Control Arm
    Hi
    I have a knocking in the rear of my car and I just got the rear tires changed, there was unusual wearing on the left tyre. I got the alignment checked and everthing was ok.
    From reading this post, it looks like the control arm.
    There is 100k on my 2003 vectra gts.
    Just a few questions.
    1. When replacing the control arm is there any other part that is recommended to be replaced.
    2. Can I diy this or should I leave it into the garage. I just started fixing problems on my veccie and enjoy getting my hands dirty.
    3. Are there specific parts for my model vectra or are they generic parts for all vectra Cs'.
    Darren
    [Ex]Admin Duncan's Avatar
    1. Not that I'm aware of - not specifically related to to the control arm anyway.
    2. Perfectly doable DIY as per the How 2 thread that you posted in. The main 'issue' is that the inner bolt on the arm can be a swine to get off - that's it really.
    3. Same part for all models.
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    what numpty above said but make sure you have a selection of extension bars, and wobble/flexible adapters too. Best bet is to go above the axle to get to the inner bolt
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    Darren,
    The rear upper control arms will cost you about £66 each from Vx or you canhave a look on ebay or LMF (vauxhall parts site) £35 each. They are not vehicle specific it is one size fits all and NOT side specific either L/R.
    The only other thing you may consider doing at the same time is the rear anti rollbar bushes (ARB). Only a few pound each from Vx.
    HTH,
    Bri.
    Bristol
    Vehicle : CDTI 150
    Done mine last weekend. Took a little over 3 hours to do both.
    Tools neded: Jack and axle stand.
    22mm &18mm ring spanners
    E22 & E18 sockets (half inch drive)
    wobble bar and knuckle joint
    torque wrench (up to 150Nm)
    75% of the job takes about 30mins a side, its the inner E18/18mm nut and bolt that take the time, access is a pig.
    Vx recommend replacing the nuts and bolts as they are angle torqued
    Jul 2009
    Waterford
    To all, tThanks for all your help.
    I am going to order the parts and get crackin on it.
    I couldn't see any of the photos' on the how2...
    Thanks again. I love this forum...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Why not upgrade to a full membership think how much you've saved, plus you get to have your own garage lol
  1. Fan Control
    By juggernaut in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2012, 08:04
  2. For Sale: Vectra Light control panel without Front Fog control: Cheap!
    By Envy in forum Parts for sale
    Last Post: 19th April 2012, 00:05
  3. Traction Control
    By crgv6 in forum Engine & Drivetrain
    Last Post: 7th January 2010, 18:42
  4. I want to fit Cruise Control to my Vec-B
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2009, 08:48
  5. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
