Results 1 to 10 of 19
Thread: Copy CD not working on CDR 2005? Why?
    Aug 2009
    Bradford
    Default Copy CD not working on CDR 2005? Why?
    Hi
    Recently bought a vectra (infact bought it y'day )
    The CD player doesn't seem to be taking any copy CD's in. Haven't tried any original CD's yet to be honest. Why do you think it isn't working? Do I need a new CD player?
    Jan 2009
    WGAF#5
    iirc dont think they play copies - only originals soemthing to do with not reading the table of contents
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by deztroyer View Post
    I have a CDR2005 in my Vectra and it plays CDR & CDRW's no problem.
    Not sure why the OP's isn't working though
    Mar 2007
    North East
    Could be the quality of the disks. The op needs to try an original really.
    Oct 2008
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I may be wrong but it has to do with what colour the written side of the disk is and how fast the disk was written hth
    Mar 2007
    North East
    True some players don't like the dye, normally best to get some decent quality silver and write at a slow speed.
    The CDR2005, and CCR2006 for that matter, can be a bit fussy about what type/brand of CD-Rs are used in it. On my CCR2006 I got some cheap CD-Rs instead of using my normal branded make that I use on the PC and it didn't like them. Switched to the branded make (Verbatim) and it played them fine.
    As said above, try an original disc first just to check the unit is okay - then try a different brand of CD-R. Start with a decent brand like Verbatim, TDK etc. and you should be fine.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    Yep, my 2005 plays CDR's all day long.
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Vectra
    Engine : 1.9 CDTI 150
    Just checking!
    When you burnt the CD did you burn in MP3 format??
    CDR2005 cannot play MP3 files that's all. Mine plays copied discs fine or make sure you finalised the disc as again the CDR2005 cannot read non-finalised discs.
    Bri.
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Vehicle : Vectra C
    Trim : Energy
    Engine : Z19DTH
    Mileage : 150,000
    Are there no issues with the CD lasers going out of alignment like the CD70's do.
    My CD70 CD drive is slightly out of alignment, and so sometimes replies that any of my CD's are an "INVALID DISC", and then spits them out. Doesn't matter if they are originals or copies!!
    I understand that the worse the alignment, then the less chance it will work!
    Just a query / suggestion as I have no experience of the half-can radios...
  1. 2005 2.2 radiator to fit a 2005 1.9 cdti 120bhp
    By IRvectra786 in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 08:59
  2. CDR 2005 Not working
    By Carl83 in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2012, 00:43
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. vectra 3.2 2005 Horn Randomly stops working? Help..
    By vec3.2 in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2009, 23:10
  5. Replies: 4
    Last Post: 25th October 2007, 08:28
cdr 2005 will not play cd
cdr 2005 troubleshooting
